Question about Dometic Rooftop RV Air Conditioner
Coleman Mach roof top ac
We just installed a new roof top ac and it is leaking on the inside of the rv.My husband took the cover and found a drain pan but no place for the water to drain..What do we need to do??
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Posted on Jun 19, 2008
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
I have a coleman Mach rooftop unit & want to connect drain tubing to carry condensate away. Is there a small drip pan with a tubing conncetion for this?
If all you want to do is re-route condensation dripping off the roof, and it's a rubber roof, one easy way is to buy a caulking tube of "Dicor" self leveling sealant for rubber roofs from RV dealer, and run a 1/4"-3/8" bead across roof from AC to wherever you want it to go, and let it cure for a couple of hours. Nobody sees it, and a tube is about $10 max.
Jun 09, 2010 | Coleman Mach III Air Conditioner
I have a 1990 rv and the air condition is leaking
The drains for that will be between the upper unit and the roof of the RV. You only have an inch or 2 to see under there so it's pretty hard sometimes, but you should see little round button like things sticking down from underside of the roof AC unit. They have holes in them, and can usually be unplugged with a stick, or piece of wire. If you can't get them cleaned out, you will have to make sure you shut breaker(power) off to unit, and remove the cover by taking out the 4 big Philips head screws. That will give you access to clean out holes in base of tray for drainage. If your getting dripping inside when unit not running but raining outside, then gasket will need to be changed.
May 13, 2010 | Coleman Mach III Air Conditioner
Leaks inside when running
you might have a drain line plugged up...or a dirty evap coil...call if you need direction an what to look for...
May 12, 2010 | Dometic Rooftop RV Air Conditioner
Leaks where it sets on roof how does it bolt to the roof
There is a bolt on each corner that tighten from the inside. You will see them when you remove the inside cover. There should be foam weather stripping around the opening that the unit sits on and then it's tightened up.
Oct 13, 2009 | Coleman Mach 15 Air Conditioner
Appears to be condensation leaking from the Carrier roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back bed and floor. Thanks, Richard
there should be a pan under the evaporator coil in the roof mounted unit, the pan should have a hose on it to remove the water to a non objectionable place, you need to locate the drain and pressure it up to clear it, I would also remove the top covaer and check the cleanliness of the coil drain pan itself
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
Where are the drainage hoses located on a 2005 coleman rv ac
many times the pan of the evaporator in intergral with the drainage. You need to pull the cover and see which way the pan is pitched you should be able to trace it that way.
Jul 12, 2009 | Coleman Mach 15 Air Conditioner
Should there be a condensation hose of some sort. I have a leak and can't find where water is coming from
These units do not have condensation "hoses", they have an evaporator pan than is located under the evaporator coil and catches the condensation and then lets it drip down onto the roof and then off the RV. If your AC is leaking into the inside, remove the inner shroud and feel up into the evaporator area for the pan. If it is full, then the drain holes are plugged. They are not easy to get to. Remove the upper shroud and then remove the front cover over the evaporator. At the base of this area is the pan, on each end is the drain hole. Clean them out and all should be fine.
Hope this helps,
Jeff
Rate me please!!
Jul 07, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
872 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
