Question about Dell Axim X30 Pocket PC
Pozz Ja imam problem na dva Dell Axim x30,624 MHz,non stop mi pokazuje Aligin screen,znam da treba da se flashuju ali gde?Znas li neki servis u Beogradu gde bih to mogao uraditi? Vlada
    Novelist:
  • 198 Answers
Please re-post the question in english because unfortunately i don't understand exactly the nature of the problem.
From what i get, i think you have a problem with the touchscreen allignment wich seems to be out of phase. This is mostly a hardware problem between the touchscreen controller and the motherboad. Also, a touchscreen has a finite life span and will loose accuracy over time and fail completely in the end. You should try a hard reset for your dell, (this will erase all the data stored on it and replace it with factory defaults). If this doesn't work, most probably the only way to save the device would be to have the touchscreen or lcd-touchscreen unit replaced in a service center.
Hope it helps.
Posted on Jun 19, 2008
Imam hp pavilion dv 7 laptop i u njemu ugradenu kameru hp webcam ali ju nemogu ukljuciti
Sve u svemu, izgleda mi da treba da instaliras nove drajvere. Nasao sam ove sajtove, ali molim te prvo proveri koja verzija windowsa imas (32 bitna ili 64bitna) Mozes da proveris za desni klik na iconu My Computera i selektiranjem Properties. Trazi nesto gde pise 32bit operating system ili 64 bit operating sistem. Ondak skini nove drajvere sa ove linkove
32 bitan - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-75835-1&lc=en&dlc=fi&cc=fi&lang=fi&os=4062&product=3939026
64 bitan - http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-75835-1&lc=en&dlc=fi&cc=fi&lang=fi&os=4063&product=3939026
skini odgovarajuche i sa srecom :)
Oct 22, 2012 | HP Pavilion dv7-1137us Notebook
Jako mi je potrebno parts manuals imaging unit phaser740 ili jpg
Contact Xerox directly to request or order parts manuals.
Aug 06, 2017 | Xerox Office Equipment & Supplies
IMAM DIGITALNI FOTOAPARAT ZNAMKE PRAKTICA,IN KO GA PRIZGEM MI PISE lens error 1114 IN NATO SE APARAT UGASNE IN NE POVLECE NAZAJOBJEKTIVA
Type text or a website address or translate a document. Cancel Listen English to Slovenian translation Pozdravljeni
Problem je, da je objektiv zagozdi v sod. Obstaja nekaj DIY rešitve, ki jih lahko poskusite, vendar pa je verjetnost, da boste morali dobiti jo dolo?i strokovni.
Uporabljajte jih na lastno odgovornost, saj lahko nadaljnjo škodo kamero.
Najprej poskusite priklju?ite adapter za izmeni?ni tok ali usb kabel.
Poskusite gospodarstvo spro?ilec, medtem ko preklapljanje na kameri.
Poglej objektiv, in ?e je nekaj na objektivu krogov "poravnan ali ne koncentri?ni poskušajte wiggling (dr?ite objektiv navzdol).
Poskusite ne?no potiska ali vle?e objektiv, ko se razteza vendar je to tvegano, ker lahko povzro?i cevi objektiva za zdrsnil iz njenih usmeritev sistema.
Drug na?in za to je, da se objektiv navzdol na trdo površino in jo nato mo? gor. Bodite prepri?ani, da uporabite mehko krpo ali kaj podobnega, kot da ni ni? svoj objektiv in ohišje. Naj objektiv push kamero gor in dol nekaj ?asa in v?asih malo odpora, ki ga je kamera dovolj, da stvari gredo spet.
Poskusite hitting vaš fotoaparat v bli?ini le? na telo z mehko tkivo na dlani.
Razen to, jaz bi fotoaparat na popravilo center za oceno, da vidim, ?e bi stalo ve? za popravilo kot zamenjati fotoaparat.
?e je še vedno pod garancijo, jaz bi jo vzamete, preden poskušate koli od teh korakov in odstranite vse off-brand baterije ali dodatki, kot so nekatere trgovine so res sitna o garancijska popravila na kamero z dodatki, ki niso znamke.
Prav tako lahko imajo pogled na link TO.
Upam, da je koristno svetuje. prosimo, ne oklevajte in mi sporo?ite, ?e potrebujete nadaljnjo pomo?. Prav tako, bodite tako prijazni, da mi sporo?ite, ?e ste našli to koristno.
S spoštovanjem
Andrea
Nov 21, 2010 | Cameras
Facebook profil mi je provaljen, al sam se ja nekako domogla gmail-a i sada bih trebala moÄ?i na facebook, ali mi piÅ¡e da je suspendiran, kako da rijeÅ¡im to i ponovno vratim...
neko mi je provalio na facebook profil i promenio sifru i ja ne mogu da udjem vise na svoj profil,...sta da radim? ne znam ni svoju gmail sifru koja bi mozda olaksala stvar!! :( pomozite mi,...hvala..
Oct 10, 2010 | Facebook Social Network
Molim vas da mi pomognete otkljucati nokia 2610 - type RH-86 IMEI 355528016122419 koji je sada na T-Mobile mrezi.Ja sam pokusao dva puta ali mobitel ne prihvaca cod. ...
kako da otkljucam nokia 2130c XpressMusic koji je bio pod sifrom kad se otkljucava i nakon nekoliko pokusaja da se otkljucaa sa drugim siframa izbrisao je onu prvu i sad nmg da ga otkljucam... :/
pomoziteee...
Unapred hvala! :)
Aug 27, 2010 | Nokia 6303 Cell Phone
Cao Bogdane
never put email here ,ever, or get SPAM endless for 100 years. wow.
this is an English forum.,
here I used google translate for you
quoted and commented:
"I have one problem.
Namely, I need to perform an experiment with temperature measurement using thermopar. ?????????
I plugged the heaters into the HP 3497 acquisition cortex.
I connect this HP via IEEE488 connections to PC via ISA card (iee 488 card).
WE DONT USE ISA card today, in USA> and software for this is hard to find in year 2017,
The problem is that I can not intimidate that card to work under XP.
WE DONT USE XP today in USA it's a VIRUS MAGNET>!
Do you have any solution?
And do you know a program by which I can read these measurements? I wrote some programs in qbasic.
I installed Labview, but it seems to me that it's quite complex.
I need some simple program, possibly with visualization.
ITS NOT SIMPLE at all to make 488 work.
Thanks in advance
My guess, is you are trying to use HP-IB (IEEE488) communications, cables ( a parallel 2 way comms)
to some ?instruments.? (ask the instrument maker yet)
My guess they are long ago no longer in business or the products are long long gone now.
why not tell the full information on this instrument./?????
makers name, and model #
that takes working software on the PC side.
(drivers for the ISA, and APPS to run it)
the Maker of the instrument would have APP software to run that.
ask them?
if not, you get to write your own software,
and would need the IEEE488 comms library to do that ,and buy it.
you';d also need the book in the instrument in order to learn
the IEEE488, command sets , and address and data forumats.
or its impossible.
Apr 06, 2017 | Compaq Computers & Internet
Dell Axim X30 Pocket PC Logo
110 people viewed this question
Alun Cox
