Question about Ovens
GE OVEN MODEL#JTP15WD1WW / REPLACING OVEN CONTROL PANEL DUE TO FAULT CODE. NEW CONTROL PANEL (AP3140312) HAS DIFFERENT WIRE TERMINAL NOMINCLATURE THAN THE OLD ONE BEING REPLACED. HECK, THE NEW CONTROL PANEL DOESN'T HAVE A GROUNDING TERMINAL ON THE BOARD LIKE THE OLD ONE HAD. MOST WIRE CONNECTIONS ARE THE SAME HOWEVER THERE ARE ABOUT THREE THAT ARE ATTACHED TO THE BACK OF TWO(2) RELAY APPEARING DEVICES -? CAN FORWARD PICS. HAVE DOUBLE CHECKED FOR CORRECT REPLACEMENT PART - SEEMS I HAVE THE CORRECT ONE - WICH IS USED AS A REPLACEMENT OVEN CONTROL FOR A NUMBER OF DIFFERENT GE OVEN MODELS.
2 Suggested Answers
SOURCE:
  • 1796 Answers
SOURCE: GE MODEL#JTPI5WD1WW (10 yrs OLD), REPLACING OVEN
HI!!
THE REPLACEMENT PART FOR THIS UNIT DO NOT SHOW ANY MODIFICATION, THIS IS A PICTURE OF THE OVEN CONTROL, CHECK IF IT IS THE SAME YOU HAVE. Part Number GE AP3140312 - Ovn control
KEEP ME POSTED!!
Posted on Oct 23, 2010
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
JTP15Wd1WW electric wall oven start button not working
I ordered a new control board and it did not fix my issue, I found that my ribbon cable is touching one of the boxes and getting hot, when I bend it away from the board, my button works, I used electrical tape to keep it from touching. It could be just a bad ribbon cable instead which costs about 25.00 , you have to know the exact number of pins your unit will need
Jun 17, 2014 | GE JTP15 Electric Single Oven
GE OVEN JTP15WD1WW ELEMENT COMES ON BY ITSELF WITHOUT TOUCHING START
When you installed the control board was it part number WB27T10305? The reason I ask is because the problem that you are describing sounds like a stuck relay on the main control board, the part number listed above
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | GE Ovens
F1 code comes up on my ge double oven
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Nov 25, 2011 | GE Profile JTP56 Electric Double Oven
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    GE ModelJTP14 oven, after 30 minutes at 350, the oven flashed a F2 code. Cooled and restarted the oven at 350, after 26 minutes it flashed F3. I have been remodeling and have taken the oven out of the...
    check the codes for your particular model..they are included witht he wiring diagram that came with your oven. F2 likely means your control board (ERC) has an issue. I can't vouch for accuracy but here's another location with fault code listings http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes
    You can try turning the circuit breaker off that feeds power to your oven ( in your house electrical panel) that might work. If it does not, unfortunately it might be indicating a need to replace the control board... good luck!
    Jul 13, 2009 | GE JTP15 Electric Single Oven
    Where to connect third (yellow) wire to lower heating element
    A local appliance repairman solved the problem in ten minutes. Charged me $30.00. The two black wires fasten to one terminal, the yellow wire fastens to the other.
    I notice you have billed me for your service. Your ads advice if the problem cannot be solved by your technicians, there is no charge. Please credit my account.
    Nov 12, 2008 | GE JKS06BFBB Electric Single Oven
    F3 Error
    This is due to a Defective control board..You have to get it replaced..
    Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
    Ovens Logo
    78 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Are you an Oven Expert? Answer questions, earn points and help others
