Question about HP Computers & Internet
How to use print screen feature - HP Computers & Internet
    New Friend:
  • 36 Answers
Njt46,
Print screen will take a screenshot of whatever you have showing on your computer (Minus the cursor), and save it to clipboard.
To use Print Screen:
Simply press the key labelled "PRT SC" or "PRINT SCREEN" (or, if you're using a laptop, you will often have to hold the "FN" key and then press the "PRT SC" or "PRINT SCREEN" key).
Then open your favorite image editing program (Windows comes loaded with MS Paint), click on "Edit" at the top, and select "Paste" (Windows 7 users can just click on "Paste" on the far left of the ribbon). Then, simply save the file, and you're good to go!
Hope this helps.
-S
Posted on Oct 24, 2010
SOURCE:
When I press the PrtScrn button nothing happens. I can not find a way to print the screen
To do a "Print Screen, hold down the Shift Key and Hit PritScrn. Open Paint or some other graphics program and paste the image. This will paste the print screen to the graphics program and you can then edit, print or manage the print screen any way you desire. Let me know if you require additional assistance.
May 22, 2011 | Acer 91.63X07.001 Keyboard
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
Have connected camera directly to printer, don't seem to be able to initiate the printing process.
hi jalemn,
if your printer has a feature of direct printing then there should have an LCD screen where you will be able to navigate your camera for printing..because if no LCD screen monitor then its hard for us to choose our existing images.,try also using a PC for it to test.
mastergani
Feb 08, 2011 | Lexmark All-in-One Printer with PictBridge
Colors don't match, or even come close to the screen. There are many options in the print menu, which is best? I print from Photoshop, CS3, on premium glossy stock
You will rarely get what you see on the screen without lots of experiment. The reason being that your screen is Backlit, so what you see is not what you are going to get. Often that pic that has a nice glow appears quite ordinary and even darker when printed. Print thumbnail first and then alter parameters and print thumbnails again till you get as close to the onscreen pic as you can.
also use some of the customizable features in PRINT properties when you send it to the printer
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Epson Stylus Photo 1400 Printer
How do I use the print screen feature? When I press the ''print screen'' button I can't paste it into my email message.
you have to hold down either the CNTRL button OR the ALT button while you push print screen. One will capture the whole desktop and the other will capture only the active window.
Apr 16, 2010 | Computers & Internet
I want to copy and paste a web page to adobe photoshop. Control print screen control paste doesn't work...any advice
You need Adobe professional to acquire the web page or use the print screen feature through Microsoft word then import.
Jan 18, 2010 | Compaq Presario M2000 Notebook
How do I use the printscreen key feature?
Have the computer screen on the item you wish to "copy" then hit the Print Screen key, without copying anything else so that your picture stays on the clipboard (or "in the mouse") go to your picture editing program, ie. Windows Paint, Paint Shop Pro, IrfanView (a freee downloadable program) and click on "Edit" then "Paste" and then save the final product.
Nov 19, 2009 | Microsoft Wireless Laser Desktop 4000...
Authorware Printscreen doesnt print actual document fullsize
Try printing document thru your printer rather than Printscreen feature. Or Printscreen feature copies to clip board which you should be able to open and paste to new document then use your printer set up to adjust. Make sure your printer set up is set to scale to fit page.
Aug 24, 2009 | Adobe Macromedia Authorware 7 Full Version...
Can not get rid of gaps with repeated Nozzle head cleaning
first of all, the nozzle check just tells you if there is a clogged nozzle, which you already know. you have to use the head cleaning feature on the same screen right below nozzle check. run that about 2 to 5 times and it should be cleared up!
Dec 09, 2008 | Epson Stylus 880 InkJet Color Printer
Royal TQ 840
There should be either a switch or a coded feature that is set to "delay" print usually you have to hold the code key down then press the key button (probably one of the number keys)under the feature that says delay.
Aug 31, 2007 | Royal Satellite 40 Typewriter
Open Questions:
HP PRINTER Technical Support # I:8OO-8O3-IO69 Phone Number This HP PRINTER USA phone number is ranked #2 out of 2 because 7,728 HP PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O3IO69 is to reach the HP PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, HP PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO803IO69 and ways to call or contact HP PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP PRINTER USA Calling HP PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP PRINTER USA's phone numbers against each other. Contacting HP PRINTER USA in General While I8OO803IO69 is HP PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO803IO69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HP PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP PRINTER USA.
Oct 16, 2019 | HP Computers & Internet
HP PRINTER Technical Support Phone # I:888-67O-O271 Number This HP PRINTER USA phone number is ranked #2 out of 2 because 7,728 HP PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:888:,:67OO27I is to reach the HP PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, HP PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about ************ and ways to call or contact HP PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP PRINTER USA Calling HP PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP PRINTER USA's phone numbers against each other. Contacting HP PRINTER USA in General While ************ is HP PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that ************ is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HP PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP PRINTER USA.
Computers & Internet Logo
657 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
