Question about Sunpentown Vacuums
My uf - 311w freezer when pluged in u feel the moter running but it does not kick it to run the freezer. it sound like the start relay is it the small round switch numberljux-28gcf rohs on where the terminals are other side is drb4 b77-120 2006.07 this is a 3.1 cf freezer
If my overload protecter reset part is broken wont that stop the moter from running
It's possible the motor may run if the reset is broken but it may prevent the motor from shutting off properly in case of an overload.
Apr 01, 2016 | Kenmore 24212 Whispertone Bagged Canister...
VACUUM FAILED TO AUTOMATICALLY START AFTER PUTTING ON A NOTHER POWER TOOL
did it start and run for a second before you tryed pluging the power tool in
Feb 18, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Magic chef model #MCWC45A Serial # 0902mcwc45a09720. It is a bit over a year old. it just went dead. no compressor sound.No interior light. Unplugged it, and after a day plugged it back the the compressor...
It sounds like the compressor is going bad, but you can try to change the start components and overload to make sure they aren't at fault......
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Vacuums
Hoover elite s3825 won't turn on. How do I open it up to get at motor etc
your problem sounds like your switch. I would advise against going into the moter as it sounds to me that its running ok. Hope this helps. Chris
Feb 06, 2011 | Hoover Vacuums
Have a bottom mount viking refrigerator, making a loud noise and the alrm is going off for the high heat
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 05, 2011 | Vacuums
Last night vacuum started making high pitched sounds. Sounded like motor was running way to fast. The hepa filter on side of product was blown off. I checked the belt, and was in tact but has a few...
Hello, I don't belive it is the filters, the motor sounds like it is bad, whihc will be happen more offen on bagless vacuums, they need more reapir work. The best choice for a vacuum is a bagged machine, and Miele / Riccar and Oreck are the Best. If I can help feel free to call 1561-848-3387 Thank you, Teresa. Clean sweep Vacuums.
Aug 10, 2010 | Hoover U5296-900 Upright Vacuum
Bissell proheat isn't spraying water out
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 04, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat not dispensing water
heatman101
Mar 27, 2010 | Bissell 1699 ProHeat Clear View Upright...
My dyson turns on only when in the tilted
it sounds like the wires attached 2 the moter are lose need hex drive 2 take a part moters verry fidley stripped quiet a few moters were gone
Oct 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wiring schematic oreck xl2600hh
I have a Oreck XL and the propeller that is in the housing will become hard for the moter to turn. I have took it apart and do not see a problem, but when I reinstall the parts it will run for about 15 sec. and the moter will stop turning. When the propeller housing is off the motor turns ok and doesn't stop. Do I need a new propeller/housing?
Nov 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
358 people viewed this question
Top Sunpentown Vacuums Experts
Marvin
Marvin
JoeVacs
Are you a Sunpentown Vacuum Expert? Answer questions, earn points and help others
