Question about 3Com U.S. Robotics Faxmodem 56K
I need the version software to set up (3com u.s.robotics 56k faxmodem). Help me,thank. Nguyen xuan Hiep
Missing driver for PCI Serial controller device: PCI\VEN_12B9&DEV_1008&SUBSYS_00A212B9&REV_01
Try Device Doctor portable: http://www.devicedoctor.com/device-doctor-builds.php
or
SlimDrivers Free version: http://www.driverupdate.net/download.php
Mar 22, 2011 | Computers & Internet
My computer does not detect the modem
Well Some Faxmodem The Software as to be install first ... Check Make shure your Unit is On first and check the usb cable if is ok and connected correcly on the modem and on the PC.
Sep 22, 2010 | 3Com U.S. Robotics 56K USB Faxmodem...
U.S ROBOTICS 56K VIA RS-232 FOR VISTA HOME
You can download the modem driver from US Robotics WEB site.
Use this link :-
www.usr.com/support/s-main-menu.asp
Aug 03, 2009 | 3Com U.S. Robotics Faxmodem 56K
I need instaltion software 5633b
try this:
http://www.usr.com/support/product-template.asp?prod=5633a
Jul 31, 2009 | U.S. Robotics (USR5633A) Modem
U.S ROBOTICS 56K FAXMODEM DRIVER SOFTWARE REQUIRED(EXTERNAL MODEM
hi
here is the link
http://www.usr.com/support/product-template.asp?prod=5686e
May 20, 2009 | U.S. Robotics (USR5633A) Modem
U.S. Robotics Faxmodem 56K on Vista via RS-232
Located new Vista driver installed and worked, both driver and operator error.
Mar 19, 2009 | 3Com U.S. Robotics Faxmodem 56K
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
Power supply for 3Com U.S. Robotics fax modem.
You need 9V/1A supply (with +9V at center pin) for your model with beige case. Do not use 22V/1.5A supply for old 33.6k model with
gray case. The shapes of the cases are very similar (56k has fever
leds, no external volume control, and no connectors for external
telephone equipment and external speaker), but the power supply
voltages and currents are completely different.
I hope this will help.
3Com U.S. Robotics Faxmodem 56K Logo
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
