Question about Nordic Track NordicTrack Professional Series 3500 - NTL34905
I have a NoerdicTrack C1900 about 2003 .......it was in a room and not used. moved it to the garage and it has no power. It was moved on a dolly and was not drop or anything. BUT the room that it was in some one smoked. I hope you have a solution Thank you lynda
    New Friend:
  • 15 Answers
Lynda there should be a reset button located some were near the bottom front of the machine try hitting the reset button, it acts as a circuit breaker switch.
Posted on Oct 25, 2010
SOURCE:
Move auto to a dolly to take to shop?
Using an automotive dolly can be risky, If the vehicle is front wheel drive then dolly the front, if it is rear wheel drive then dolly the rear. If it is 4 wheel drive and late model with no neutral shift position dolly the front and remove the rear drive shaft at the rear axle. If the vehicle is older 4 wheel drive with neutral selection for the transfer case then simply shift to neutral and dolly the front axle. Most transmissions whither automatic or manual will be damaged if the engine is not running while the vehicle is in motion.
the engines crankshaft or the transmissions input shaft must turn to lubricate the transmission unless the transmission is automatic and has a rear pump that can lubricate the transmission if the transmissions output shaft is turned in normal rotation for forward direction of travel. This is the only way to to assure there is no damage to the drive train. Be sure to follow all recommended tie down procedures. remember the dolly rotates under the vehicle so one or the other of the wheels must be able to move forward and back to allow for corners. Try to always choose a path that allows forward direction unless you are an expert driver with experience and able to back a farm wagon type axle trailer (like covered wagon) going backward will be a challenge even for someone experienced pulling a bumper pull trailer.
To get the vehicle onto a dolly have some friends help push or use a cable puller to move the vehicle onto the dolly.
Feb 15, 2015 | Cars & Trucks
Name those moving companies of London who modern technology during removals day.
There are many removal companies of London who use latest technology. I have mentioned a website below, in this removal directory there are almost 8 removal companies of London. These companies use latest equipments which are especially made for removals task. They use heavy-duty fixed bar panel cart, padded tubes, dolly risers, pallet jacks, foam, stretch film etc.
Removal Companies London
Jul 23, 2013 | Starrett D125 Digitape 1Inch x 25...
The battery is dead and the car is in the garage and when I turn the key to switch it out of parking gear it wont go I need to push it out of the garage
YOU NEED BATTERY POWER TO ENERGIZE THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID TO SHIFT TRANSMISSION TO ANY GEAR.TRY USING A JUMPER BOOSTER BATTERY TO POWER CAR UP ENOUGH TO SHIFT IT OUT OF PARK TO MOVE IT.
Mar 24, 2011 | 1996 Ford Contour
Any tricks to moving tv to a new location?
Just make sure u move this tv up right position only.CRTS colors tubes guns have chemicals insides of it.Just use a Dolly,protect the tv screen panel with a heavy piece of cloth.Ties it tight to a Dolly.Two people help each sides and one person pull the Dolly.U should be find moving the tv to a new location.
Oct 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My 04 silverado 1500 was stolen from by my boyfriends brother I found it and can not locate the keys. The dealer want $85.00 to get the key code and AAA wants 140 to make a key. I can't afford that. How...
my past experience says this won.t happen this vehicle has a anti-theft that want allow vehicle to run unless it detects key that is why the cost is high and unfortunately your only other solution is to put on tow dolly but if no access to a dolly or no money this will be problem
Aug 18, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
Reccomendations on how to move a Hobart H600 Mixer
I would use the 4 wheel platform dollies and ratcheting tie-down straps to secure it to the dollies.
I have used these to move pianos and other larger objects, but make sure that you secure the object to the dolly and get the best one with the biggest wheels that you can find. The bigger the wheel the easier the roll. Not sure how big your doorways are, but if you can use 2 or 3 dollies, that’s what I would recommend. Just make sure that you secure the load with ratcheting straps not just rope.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
May 23, 2009 | Hobart A200 Stand Mixer
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Moving Information
Poczekaj, not a good idea to break it down, screen assembly is veery fragile when not installed into the set, best thing to do is rent a refridgerator type dolly, wrap the front of the set with blankets and then put the dolly under the side of the tv, winch up the strap and with 2 people walk it up the stairs, one pulling the dolly the other person at the other end to push upwards, slow and easy and you`ll have no problem, if hauling in a pick-up it MUST be winched down to the bed or it will fall, (been there done that :) hope this is what you needed, more questions? feel free to e-mail me back, Happy Holidays, BMW Rider
Dec 10, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Nordic Track NordicTrack Professional Series 3500 - NTL34905 Logo
344 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
