Question about SanDisk Sansa e250 MP3 Player
Keep freezing my sansa e250 whenever you put it on it goes to refresh data then the screen goes white then it starts all over again untill the battery goes dead
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Sansa freezes
try inserting a microSD card when player is turned off then put it on...work most of the times...
Sep 10, 2009 | SanDisk Sansa e250 MP3 Player
Refresh database
Get the recovery tool from Sandisk Support downloads. Put it in a file you can easily find.
plug in the Sansa, once it turns on, hold the power button until it turns off then switch the hold switch at the top edge of the player to hold (showing orange) and then hold the "Record" button on the side until the player turns on with a black screen, saying it is in recovery mode.
Some people have said they had to hold both "Power" and "Record" to make it work.
Run the recovery tool software and you should be running again.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 not finishing its "Refresh Database"
Turn it to recovery mode by putting it on hold, while off, and holding the record button along with power until it go's into a screen with a black background and white text. Then update it with the updater.
Or try formating it while it's in MSC USB mode which you can change in the settings on the player. Just connect it while in the MSC mode and, while in "my computer", click the "SANSA e250" drive icon and click format. But when you format it, do not click "Quick Format" or change any settings. JUST click start.
I hope it works for you. If you have any more problems or it doesn't work, i will be more than happy to help you. Just write a response back and i will get to it as soon as possible. Thank you and have a good day.
Dec 21, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa e250 MP3 is buggin
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
Black screen
i dont know what the problem might be but u should try calling sandisk they should know what to do. hope it helps
Jul 11, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
