Factory reset:
Push in the small reset button on the back for 10 seconds, remove the power cable, while holding the reset button, and plug it back in after 10 seconds, keep the reset button pushed in until all the lights on the front start to blink.
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken. Lamp replacement procedure would be written in user manual of tv. And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard. If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.Plugging the video cable back in should fix the problem. I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you. Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
