Question about Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Aquarius WM7 730 on wash cycle, keeps going around and around, never gets to the fabric condition or spin cycle!! does this on 5 and 13 and probably the rest of the washes too. I have to put it onto rinse manually sometimes 4 hours after it was put onto a 60' wash. it does occasionaly wash to spec, suggesting a dry joint or sensor problem maybe?? Thanks Ian
    Top Expert:
  • Hotpoint Master
  • 64,259 Answers
Probably the PCB has failed . I hate new electronic things . OLD mechanical fail less often
Posted on Sep 07, 2017
SOURCE:
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
  • 30 Answers
SOURCE: Hotpoint Aquarius WF000 Washer
make sure you have both water valves working and check your water pressure is good too hope this helps
Posted on May 15, 2008
barkencoa
  • 3463 Answers
SOURCE: Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: hi i have a Hotpoint WD640 1400 spin Aquarius +
How do fit a hotpoint dryer thermistor to a hotpoint wd640 washer/dryer
Posted on Jul 07, 2009
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
Black on door seal and water filling fabric softner section in dr
hotpoint Aquarius
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Washing Machines
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint w440 washer/dryer keeps repeating cycle load?
Hi there, I've got a Hotpoint Aquarius washer / dryer and this has just started happening to me - it seems to get to the end of the cycle then repeat itself. However, I do not seem to be able to cancel the cycle, or am I able to switch it off. It's been going for about 4 hours now. Any ideas?
Feb 22, 2009 | Hotpoint Aquarius WD63 Front Load...
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
