Question about Mitsubishi CS-40503 TV
Tv has no powern outlets are fine, no power when I turn on the power
  • phaeling63 Oct 24, 2010
    I tried what you suggested and nothing happened.
  • Mitsubishi Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Oct 24, 2010
  • 10,865 Answers
Hi. Many Mitsubishi tv's will generate an error code. To see if yours will do this: Attempt to turn on Tv, after it shuts down go up to the front panel, press and hold Menu & Device, the light on the front will start blinking a two digit code and will repeat the code several times, examples of the code are 12, 34, 23, etc. Most common shut down problem is convergence IC's and fuses.
Once you know what the problem is you can get back on here with the exact problem or you can just call a couple tv repair stores and get firm estimates over the phone on what they would charge. Joe
SOURCE:
My Panasonic PT-50LC13 HDTV won't turn on. No blinking lights, nothing. Was working fine a couple of hours before and only unplugged it to move it to a different table a couple feet away. Hasn't worked...
Did you use a new electrical outlet? If so, have you confirmed the new outlet has power?
Did you try moving the TV back to the original outlet and confirm the TV will not power up?
Apr 05, 2018 | Panasonic Televison & Video
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
42 inch plasma screen tv Panasonic was working fine then turned it off and now won't turn back on. Any ideas? Can't tell if it's getting powered and none of the caps are bulged
Did you try the outlet that your TV is plug into. or get a extention cordand try your TV in other outlet.Then you know if it's the TV or the outlet.
Jan 14, 2013 | Televison & Video
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Won't turn on/no power. Worked fine until i turned it off as usual, went to turn it on, no power either from "ON" button or remote. wall outlet works fine, tried it in other outlets, no luck.
Well, I used to be an authorized Apex repair center and absolutly could not get a part for a tv. You may just have a bad H.O.T. ( horizontal ouput transistor) which is what I needed. I don't even know if they are still in business. Good luck.
Oct 23, 2009 | Apex Digital AT2402 24" TV
TV won't turn on
it might be the power supply failing . the caps are known to go bad,
Jul 08, 2009 | Polaroid FLM-3201 Television
No light, sound nor green button
maybe a lizard is die inside and shock your power supply circuit
Jul 01, 2009 | RCA 36F530T 36" TV
Had the digital cable box installed yesterday. The tv worked
The cable box has an AC outlet on the back of it and sometimes the installer plugs the TV power cord into it. This outlet has two modes--IE: on all the time or switched. If the outlet happens to be programmed to the switched mode, the cable box has to be on before you can turn on the TV. If the outlet is on all the time, then you can turn the TV on at will. So, you have to decide if the TV is plugged in there or it is plugged into the wall recptacle. If none of this explanation fits, then we need more information.
Jan 07, 2009 | Hitachi 46UX24B/25K 46" Rear Projection...
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
