A well know problem to the Behringer Truth B2031A speakers is radio interference and noise. I had the same problem with mine and found a solution on a forum!
If you open the speakers, you'll see a cable from the main board that runs to the 2 lights at the front (on/limit LED's). It functions as an antenna... Disconnect it and your speakers are silent, finally. (OK no leds, but I can live with that).
Great solution! While not quieting my monitors completely, this tip pointed me toward a complete solution: Shielded wiring for the LED wiring and a screening cover made with sheet metal. If you look at the PCB they are mounting holes for what should had be a shield. (a leftover from Behringer...)
Greetings!
ZaD MoFo could you elaborate on this screening cover? Where exactly do you put it, and what exactly should it be shaped like? thanks
