Altec lansing im7 does not power up!
Every time I insert the power connector, I get a spark, but the speakers do not power-up.
  • 9 more comments
  • kev_barry Jun 24, 2008
    i have the same problem. No power to im7 and seeing a spark when the power cable is plugged in at the back of the unit. Any ideas??
  • larry1948 Jun 30, 2008
    I am having the same experience -suddenly, with no abuse or anything.
  • Anonymous Jul 03, 2008
    My Altec Lansing im7 worked for a few months, but now doesn't power up. It's as if the power button is inoperative - the power light doesn't light up when the power button is pressed, nor do I even hear the "spark" that the previous commenter hears.
  • macmad813 Jul 19, 2008
    i have the same problem any solution?
  • Anonymous Aug 01, 2008
    Same problem here. Mine worked just fine for over a year. Then it just stopped. The LED doesn't light up. I tried batteries as well and that didn't change anything.
  • ReddBird Aug 06, 2008
    I'm having the same problem with my IM7. It worked perfectly for a year then began spontaneously powering off after 10-15 minutes if play. After that point, I could power it back up by pressing the power button but it would only play for a few minutes before shutting off again. I called Altec Lansing and was told that the IM7 is no longer in production. The service rep said it might be the power supply but I have not been able to locate a genuine one or even a generic power supply. I'll post again after I investigate further.
  • otis390 Aug 19, 2008
    I'm having the same problem, After one year nothing on the power cord. But my unit works normal when I run on batteries. Very frustrating when you call Altex and they have replacements. Not sure I’ll buy from them again.
  • Anonymous Oct 22, 2008
    Same problem, no power to the unit. The problem seems due to the connection between the power cord plug and the socket. Tried to open the unit, but the front cover was clued on from inside, very strange!
  • thomcat40 Jan 11, 2009
    Are you referring to the Cord and power pak that comes with the unit, or are you talking about inside the unit? I tried my friends power cord and it still doesn't come on? Any suggestions?
  • larry1948 May 11, 2010
    I bought the batteries and put them in - nothing. Got to doubt the problem is with the external power supply.
    Has anyone figured out how to open the unit itself to see if any replaceable part is fried?
    Have any of you tried to use the unit with batteries to see if the issue is within the unit or in the power supply? Funny, I don't even have 8 "D" Cells in the house.
Altec no longer makes the power supply. However you can find used ones on eBay for about $25. I went to my local electronics store and bought an 18V, 2 amp power supply for $14. It works great and charges the iPod just like the OEM power supply. The store I purchased it from is JK Electronics in Westminster, CA 714-890-4001.
Posted on Aug 07, 2008
Hi, iam searching for the left "bas speaker" that have been cracked on my IM7, and the remote control.
Do you have an broken IM7, and want to earn some $$?, dont hesetate to contact me!
Posted on Jun 27, 2009
Mljrucla77 Is correct. I purchased the same from JK Electronics and had the same result. Thanks, without a replacement power supply I would need to buy a whole new unit.
Posted on Aug 29, 2008
Why is the electric power supply converted to 17volts, but if you use 8 D type batteries the power supply is 12 volts. How can there be such a big differance in power supply?
Posted on Aug 13, 2008
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
IM7 power is turning on (the blue light goes on) but no sound is coming out of the speakers.
I have the exact same issue. Even the remote works fine, but no sound. I have even tried to use aux.
Did you find a sollution already????
Sep 21, 2011 | Altec Lansing IM7 (WMM137039)
I have a blown speaker can you tell me if they have replacement speakers for the altec lansing IM7 inmotion
Try getting an old speaker. Alternatively remove the old one by twisting the side of the speaker anticlockwise then unscrew it.
Take it to one of the speaker shops where you could either get something closer to what you have or get a coil rewind and a diaphram change.
Oct 02, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Blown bass speaker, hoping I can buy a replacement.
  1. Contact Altec Lansing.
  2. twist the Speaker frame anticlockwise to open then unscrew the speaker then look for a similar/something close to it(size and amps) one in the local audio shop.
  3. Get it to some audio shop for a recoil and or diaphram change.
May 16, 2010 | Altec Lansing inMotion iM7 (021986950806)...
My altec lansing im7 stopped working during class
I am having the same problem. Did you ever figure it out??
Jul 28, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Sparepart For Im7! LOOK HERE!
I have one that just quit all of a sudden as I was listening to it. Don't know what happened, but it "clicked" and that was it. Sounded great while it was playing, I have the remote if you are interested.
Jun 27, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Altec lansing im7 docking door
I have the same problem. I have a Brabantia bin and the catch is the same as the IM7. You can buy replacement catches from Ebay for the Brabantia Touch Bin. Just need to work out a way of swapping them over
Sep 12, 2008 | Audio Players & Recorders
Were can i get parts for a altec lansing iM7 ipod player
You won't be able to by conventional means - probably not at all.
Unconventional means:
1) Find someone selling a broken or very cheap altec lansing im7
2) Send an e-mail to the Altec product development team, and ask very nicely.
I know this is not what you want to hear, but most manufacturers either don't have parts available in the U.S., or they are not willing to sell them to customers.
Mar 19, 2008 | Audio Players & Recorders
Finding replacement Power Supply for Altec Lansing
Hi Yeo...
Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model.
I hope this was helpful.
enjoy
Feb 20, 2008 | Altec Lansing Multimedia Computer Speakers
1,891 people viewed this question
 Grubhead
Grubhead
