Question about Kenmore 84152 Electric Dryer
How do i change the dryer motor pt# 3395655 model # 11088762792 stackable
    New Friend:
I own a Kenmore stackable model 417.99370830 with motor number 5KH26GJ 067S and I would like instructions on how to replace the dryer motor.
Thank you for your response
Marvin
Posted on Jun 12, 2012
  • 3,074 Answers
Http://www.partselect.com/dryer+replace-motor+repair.htm
Posted on Oct 24, 2010
SOURCE:
Stackable dryer model # FFLG2022MW dryer turns on and spins but wont get any heat. the dryer vent has already been checked but wasnt clogged.
Heating element would be a possible cause. Also heat circuit runs thru fuses and thermostats, the timer or control, and motor. Make sure you have 220 volts getting to dryer.
Sep 24, 2018 | Dryers
Stackable frigidaire dryer
The motor winding won't have a large resistance but should have some. Be sure and unhook wires and set your meter to the lowest setting and 0 it. Be sure you are checking the correct connections.
May 18, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
What's the resistance value in stackable dryer motor model fex831fs2?
There should be some for both the motor and the heater coil. Don't know how much don't have schematic. Hope this helps
LG stackable off balance
Open the machine covers and check the tub/motor shock absorbers or dampers for condition. Best to change all if one is faulty.
Apr 11, 2014 | LG Front Load Washer & Electric Dryer...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Jul 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Kenmore 84152 Electric Dryer Logo
204 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
