Question about Fisher and Paykel GWL11 Top Load Washer
Machine was in cycle and turned off. will not turn back on. tried waiting and replugging and check wall outlet. still does not work?????
    Sergeant:
  • 239 Answers
Most likely control board failed
Posted on Oct 24, 2010
SOURCE:
Electronic panel freezes!
In reference to Kenmore washers in general:
Most washer's can be reset like a personal computer.
If the appliance does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the appliance, that requires service
Jan 23, 2018 | Kenmore Washing Machines
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
How to turn alarm off, have drainage issue waiting tech alarm driving me nuts
just unplug the unit from the wall outlet ----
now after the machine has been unplugged for awhile,, try and plug the unit back in and see if it will finish the cycle,, or just start a new cycle and see if the machine will reset.
c...
Feb 03, 2011 | Fisher and Paykel IWL12 Top Load Washer
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    The washer is saying F20 code...It drains the water once I press cancel...I just relocated it, now no longer will spin and drain water...Please help...have check hoses, water taps, everything and it drains...
    Check to be sure that the drain hose curves up higher than the washer tub. If that does not help, check to sure the unit is level...next turn the washer off, unplug the washer for a few minutes , then replug it into the wall outlet.Be sure that you are standing in a dry area and that your hands are dry. This may reset the operating system. If it has water in in after this, try the drain and spin cycle, and then try a regular quick cycle to see if it works.
    Good luck to you, and if this does not work, get back to us.If your problem is solved please let us know by rating this answer. Thank you for using FixYa.
    Dec 28, 2010 | Kenmore Elite 45986 Front Load Washer
    The machine is turning on, but when I push the buttons, nothing is happening
    You can try resetting your washing machines operating sytem.
    Turn the washer OFF
    Standing on a dry floor, unplug the washer from the outlet
    Wait several minutes
    Replug the Washer into the outlet and turn it on.
    Please let me know if this works for you.
    Dec 20, 2010 | Haier XQJ50-31 Top Load Washer
    Our xerox workcenter m15 had a paper jam. we turned the power off, fixed the jam, and turned it back on ... but no power now. We unplugged everything, replugged and tried again - no power.
    The simplest solutions:
    Plug a small apliance or light Into the wll otlet to determine if there is power in the outlet
    If the appliance does not power ON, the problem is in the power outlet. Contact your building maintenance department to check the breaker in the electrcal panel.
    If there is power check that the power cord is securely plugged in to both the wall socket and in to the machine.
    Turn off the power switch on the left-hand side of the machine; wait one minute; turn back on.
    If these steps do not resolve the problem you may need to contact a service representative.
    Dec 08, 2010 | Xerox WorkCentre M15i Laser Printer
    The list button doesn't work and I am unable to
    turn off your cable box
    turn off the dvr
    disconnect cable box from wall outlet
    disconnect dvr from wall outlet
    unplug e-sata cable from dvr
    replug e-sata cable back in to dvr
    plug dvr into wall outlet
    turn on dvr
    plug in cable box to wall outlet
    turn on cable box
    wait for cable box to go completely thru startup procedure
    ...then try your list button again.
    Mar 01, 2010 | Televison & Video
    Paper jam occurred, now printer wont print.
    1. Press the On button to turn off the HP All-in-One.
    2. Unplug the power cord from the back of the HP All-in-One.
    3. Unplug the power adapter from the wall outlet and wait 30 secs.
    4. Plug the power adapter back into the wall outlet.
    5. Plug the power cord to the back of the HP All-in-One.
    6. Press the On button to turn on the HP All-in-One.
    Feb 03, 2009 | HP Office Equipment & Supplies
    Cycle power and scan again
    power cycle means to  disconnect the power cable from the back of the printer whlie the printer is turned on,and than wait till 10 secs before repluging in the cable again.. do this step and it will resolve the probelm!
    Feb 03, 2009 | HP Officejet 5610 All-In-One InkJet...
    Fisher and Paykel GWL11 Top Load Washer Logo
    23 people viewed this question
    Top Fisher and Paykel Washing Machines Experts
    Archie Ferrarini
    Archie Ferrarini
    Gerry Harvey
    Gerry Harvey
    jimorris77
    Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
