Question about Maytag MSD2651 HE Side by Side Refrigerator
Coils freezing up in the freezer compartment fan is not running
    Guru:
  • 1,524 Answers
#1. Defrost problem. The frozen coils allow the temperature to rise causing the fan not to run.
#2. Another possibility is that the fan died and the ice build up happened, however I believe # 1 is the answer.
Posted on Oct 24, 2010
SOURCE:
Hi my fridge freezer isn't cooling or freezing it seems like its trying to go on but then stops again
Hi Gerardine.
The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
or go to this link and have a read up.
Why is my refrigerator not cooling Refrigerator
or this one.
fridge freezer isn cooling or freezing Google Search
Jul 03, 2018 | Refrigerators
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
The refrigerator not cooling the freezer evaporator coil freezing the damper working but the fan tested good but would not come on the compressor is working find . why the fan not coming on?
Some models require the door to be shut for the fan to operate. Push the door switch in and see if the fan works. When you say the freezer coils are freezing. Are the frozen or ins there a layer of frost on them. Ice is bad if covering the coils. It prevents air circulation into the fridge. The freezer will also sometimes not activate the fan until freezer section is cold enough. It will than allow air to go into fridge compartment.
If you have any more questions please feel free to comment me back.
Jul 27, 2011 | Refrigerators
Hi, Our refrigerator has stopped cooling and I desperately need to try to fix it myself. Lights still come on. Fan or something is still running but the freezer still works so I thought maybe that's what...
There is likely a problem with the defrost circuit or cold air circulating fan (but could be a low freon charge or other problem). The freezer compartment has the cooling coil with defrost heater and a fan that pulls cold air from the freezer and blows it into the fresh food compartment; based on the setting of the thermostat in the fresh food compartment.
When the defrost heater fails, the area that the cooling coil is located in eventually turns into a solid block of frost and ice. It becomes impossible for air to be drawn across the cold coil, cooled and blown into the fresh food compartment. The result is a rising temperature in the fresh food compartment - and eventually in the freezer section, too. Since the fresh food compartment contains the thermostat and the temperature never gets low enough to satisfy it - the compressor runs non-stop. That is, until the defrost timer kicks in to shut it off for 20 minutes or so.
The first thing to do is to manually defrost the freezer by accessing the cooling coil after emptying the contents of the freezer. This can be a pain in the neck to remove racks, shelves, ice maker, etc. to get to the back wall of the freezer, behind which the cooling coil is found. If you expose the cooling coil and it is encased in frost and ice it is a problem with the defrost circuit. If it is not - the fan is suspect. If the fan spins, check for a blocked path between the fan and the fresh food compartment. Defrost by placing a heat source in the freezer or directing the output of a blow dryer at the coil. If you're unable to access the cooling coil, you can simply empty the freezer and defrost it with a heat source. it will take longer to melt all the frost and ice, but it will work.
If it is a defrost circuit problem, you'll need to check voltages and continuity on the defrost terminator & timer and defrost heating element, fans, etc. after completely thawing the ice & frost.
This job isn't a good first time DIY job due to the danger of freezing skin, etc. due to possible exposure to freon in the system and the tight spaces you'll be working in with live voltages. You might want to call a pro after you've defrosted or put up another fixya request if you decide to dig in on your own and need specific help with procedures, locating parts, wiring diagrams, etc.
I hope this was a good starting point to help you decide whether to go forward or not on your own. Good luck!
Oct 07, 2010 | Kenmore Refrigerators
My side by side not cold enough; freezer works ok but not refrigerator
take the back off the freezer compartment. it sounds like its frozen up . check to see if the fan is running. when it freezes up it blocks air to fridge compartment. also check defrost tstat its a little round peice that clips on to coil with two wires
Aug 26, 2009 | Refrigerators
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments.  If there is no noticeable air coming from this vent, then the fan has died.
May 25, 2009 | KitchenAid KSRS25ILSS Side by Side...
It's a Kenmore alright
Do you have any frost buld up in freezer compartment?if so sounds like a freezing issue.If no frost build up is your fan running in freezer part if not you may need evap fan or a manual defrost.Your fan may have ice stoping it from turning.If your fan is running you may need to pull off your start switch located on your compressor.Shake it around if you here noise like burnt parts in it you will need a start switch.And remmember never turn your fridge up full blast normal is good or you will freeze it up. Good luck:)
May 28, 2008 | Kenmore 60721 Refrigerator
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MSD2651 HE Side by Side Refrigerator Logo
62 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
