Question about Kenmore 62622 Microwave Oven
Kenmore Microwave Model #665 6861 1891
I'm getting an error message - F6 - What does this mean?
  • Kenmore Master
  • 9,047 Answers
F6 appears to be a relay failure on the main board, but it may be a door switch or door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
What does an F6 error code mean?
The F6 message is an error code that indicates the microwave relay has failed. This is an internal component that will require service.
May 10, 2015 | Kenmore 69682 Microwave Oven
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Displaying error F6. What does this mean?
It would depend on the full model number of your oven.
If it has a 721 prefix, it was made by Whirlpool (by LG) and has a stuck cook relay, which we can repair very simply for $39.95 in most cases.
So please post a new help request or contact me directly with your full model number and detailed symptoms.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Jun 06, 2011 | Kenmore 66292 Microwave Oven
Error message
The F6 error code on your microwave oven is a relay failure.
Check wiring to relay 4903 for short circuits. If wiring is OK - replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore 61701 Microwave Oven
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Aug 21, 2009 | Kenmore 63792 Microwave Oven
Error code d kenmore model 665.60654 microwave
The letter "d" is indicating the microwave is in a demo/learning feature.
To cancel the "demo" mode press and hold "Kitchen Timer" for 5 seconds. Two tones will sound and the small "d" will disappear from the display.
Jun 16, 2009 | Kenmore 60654 Microwave Oven
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Dec 08, 2007 | Microwave Ovens
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Kenmore 62622 Microwave Oven Logo
1,150 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
