Question about Maytag MDG7500A Gas Dryer
I get a dirty gas smell on my clothes. It smell like burn diesel fuel. I also notices that the flame turn off , then come back on in a few minutes, is this normal, or do i have to hot of frame?
  • 3,074 Answers
You most likely have a weak, malfunctioning igniter. you can remove the lower panel and watch the ignition procedure. Here is a website that has more details that will help, Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Oct 24, 2010
SOURCE:
I have a carrier furnance model # 398AAV036060 serial # 0293A03686 it comes on for a few minutes the cuts off please help
Check for smell of gas first, call gas company if leak detected. May be a loose thermostat wire, dirty main control board, dirty/ lint filled gas tubes, mine had both. Cracked or dirty ceramic igniter (This is a BIGGIE!) or dirty flame sensor. Dirty fan sensor, or flame over sensor, and or burner safety sensors. Shut off power for 10 minutes, follow owner's manual to restart, wall thermostat might usually get set to lowest temp setting, then power turned on, then set thermostat to desired temperature?
Nov 16, 2017 | Carrier Heating & Cooling
Engine shut down after about 20 miles of riding, like it's out of gas. It will start back up after a few minute but only runs for a few miles then shuts down again.
Possible solution. Check the following 3 items: 1.Gas (or diesel) filter dirty and needs replacement. 2. Fuel pump worn and not delivering correct pressure. 3. Dirty gas tank- blocked pipe at exit of tank.
Aug 28, 2013 | Audio Players & Recorders
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Unit fires and flame seems to skip seems to go out for a half second then pops and burns again untill next skip. flam continus to burn and will heat popping is anoning. when first lights will smoke and...
Sounds like there might be some water in the fuel?
Take a strong flashlight, and shine it into the tank-- does it look dirty?-- can you see water on the bottom? Try draining and cleaning the tank, and make sure the suction filter is clean-- and in tact.
And yo are using kerosene-- not diesel fuel, right?
Mack B
Jan 19, 2011 | Reddy R115DT Oil Filled Utility Heater
My heater is a reddy heater 165,000btu. when i plug it up it will ignite, it will get a flame for about ten seconds and it shutdown. i recently replaced the ignitor because it broke and replace the fuel...
I would definitely stop burning off road diesel as it is dirty.Remove the top section of the heater and clean the fire eye with windex and a terry cloth rag, and run K1 kerosene it burns so much cleaner. Also make sure that fuel is not an issuecheck fuel filter,fuel lines and don't forget the screen in behind the nozzle.
Dec 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Burns for a few minutes but when when it goes off the pilot light goes out.
flame sensor is bad or dirty. You can try cleaning it with a piece of emery cloth or sand paper.
Dec 12, 2009 | Desa International CCL3924PTA 24" LP Gas...
I smell gas outside from the vent.Some gas odor on clothes. I de-linted the machine and vent completely.It heats and dries good,just the smell. It's a Maytag mdg4057bww..
your orfices are dirty or the air/fuel mixture needs adjusting so as to properly burn all the gas, can you see what color the flame is during operation, if it is more orange than blue your mixture is off, if it has flickers of orange it may just need the orfices cleaned out with a tip cleaner
Aug 18, 2009 | Dryers
Ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag MDG7500A Gas Dryer Logo
52 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
