Question about Ranger Pickups 19932010 Books
93 ford ranger wont start, possible clutch problem, battery and starter ok
    New Friend:
  • 28 Answers
A bad clutch would have nothing to do with a it not starting
Posted on Apr 27, 2014
SOURCE:
Ford ranger electrical
Check the starting circuit fuses. Most likely its a bad starter. If you can easily get at it. Drop it out attach a ground line between the body of the starter and any clean metal under the car. Have someone look at the starter while you try starting. If it does noithing when you turn the key to start, its time for a new one.
Jul 29, 2014 | 2003 Ford Ranger Regular Cab
When pressing on the clutch peddle my 1993 ford ranger wont start
Could be a clutch safety starter interrupt switch. ..
Apr 11, 2014 | 1993 Ford Ranger SuperCab
2002 ford ranger wont turn over?
Are you saying the engine will not crank, or not start ?
May 29, 2013 | 2002 Ford Ranger Regular Cab
Truck turns over and starts when I connect battery???? No key is even in the ignition.
Maybe the ignition is bad- or your starter solenoid stuck in engaged position?
Mar 29, 2013 | 2000 Ford Ranger SuperCab
Will not start. Battery seems to be ok, can smell fuel but engine will no turnover.
Chech starter solenoid, some ford models have a separate starter relay solenoid that fails. jump the two post to see iff the starter engages. make sure it is in nuetral.
On manual tranny chech clutch switch
Jan 17, 2011 | 1990 Ford Ranger SuperCab
96 Ranger new battery new solenoid new starter. Can roll it and pop the clutch, but key wont start. Everything turns on but no click when I turn the key.
Hello
I had the same problem with mine. It ended up being the neutral safety switch connected to the clutch pedal. At least with mine you had to hold down the clutch or the truck didnt think it was in neutral. No neutral means it wont start.
I hope that helps
Nov 25, 2010 | 1996 Ford Ranger SuperCab
2004 ford ranger wont start battery good starter good could it be the clutch safety switch
yes the clutch safty switch completes starter circuit to test just jump switch with a paperclip if truck starts switch is bad
Jun 07, 2009 | 2004 Ford Ranger
93 ranger not starting, wont turn over.
Take a volt meter and put the red probe of the meter on the engine block and the black probe on the battery Negative terminal. Have somone try to crank the car. If you get a reading of over 1/2 volt, you have a bad ground from the battery to the Engine block. Check the terminals on both ends of this wire.
If the above is OK, Put the volt meter on the battery terminals. (Red to Positive) and try cranking the car. If the voltage falls well below 9.6V your battery is bad. If 9.6 V or more, you may have somthing binding in the engine. When did this car run last?
Good Luck
Feb 07, 2009 | 2003 Ford Ranger Regular Cab
1992 Ford Ranger - Starts Sometimes.. New Clutch. Help?
take back to dealer and have them check the neutral safety switch on the clutch because if the switch is not adjusted properly you will have this problem
Jan 01, 2009 | 1992 Ford Ranger
Ranger Pickups 19932010 Books Logo
87 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
