Question about Winsource Tech Solutions TS-4500 Cross-Cut Shredder
My Tech Solutions TS4500 paper shredder will shred approximately 1/2 page of one or several sheets of paper. But at that point it chokes and will not shred any further. It will back the unshred portion out. I would imagine that it is a broken tooth on one of the gears, which now finally having gotten it open, does not look very user serviceable inside. Any ideas on what might be wrong? Any guidance on a repair? Thanks.
    Top Expert:
  • Winsource Master
  • 54,189 Answers
My experience has been that when a shredder chokes it usually is trying to tell you the bin is full but a cross-cut shredder is less susceptible. I do have a heavy duty cross-cut shredder that gets rather wonky when suffering from indigestion. Check whether the amount of bin content is affecting yours.
Posted on Jul 15, 2017
3 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: Tech Solutions shredder
Here is the info that I found:
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
Posted on Jul 11, 2009
  • 25 Answers
SOURCE: I am trying to open
There is another screw in the middle under the sticker.
Posted on Oct 24, 2010
How do i increase the number of pages that the shredder will shred at one time?
you can only shred what it will take , trying to force more in will only break it faster .
Oct 16, 2015 | Shredder Office Equipment & Supplies
Paper always packs up in the blades and it will not cut more than 1 sheet at a time. Sometimes not even that. Any solutions for this? I constantly have to dig the paper out of the blades, even after...
All x-cut shredders should be oiled. Buy some shredder oil ( this is a lightweight oil ) from your local store then pour some of the oil across the cutting blades where you insert the paper. After putting the oil in run the machine in reverse...this will help get the oil all thro the cutting mechanism. Then start shredding 1, then 2, then 3 etc, etc sheets at a time...when you hear the motor starting to "labour" to take the sheets thro'..then you have just about reached the point where "thats its maximum". You should occassionaly shred a sheet of paper with a bead of oil on it ( in an "S" pattern) to help keep the mechanism lubricated. Running the machine at about no more than 75% of its maximum capacity and regular oiling will prolong the machines life.
Dec 15, 2010 | Royal VF1012mx Shredder
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF700 Cross-Cut Shredder
Where do I get a gear to turn the shredder
Her
To:
Rick,
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder Problem
Replace the paper sensor switch
May 27, 2007 | Tech Solution TS-4500 Shredder
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
328 people viewed this question
Top Winsource Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Winsource Office Equipment and Supply Expert? Answer questions, earn points and help others
