Question about Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
The motor keeps cutting in and out, like the variable speed control is confused. What can I do?
    Problem Solver:
  • 19 Answers
There are a couple problems that could cause this. First is the trigger switch which could be worn out or have a short. The second and more common one is that the motor brushes are worn out. After a long period of use these little blocks that look like black steel blocks on springs are what rub on the rotor and they wear out. These are not steel but special high carbon blocks that are easily replaced and cost effective. Remove the housing and near the rear of the motor assembly you will find the brushes in two square holes on either side of the motor. Remove them (be sure it is unplugged) and replace them with new ones. They can be ordered directly from Bosch or from a host of suppliers on the internet.
Posted on Feb 24, 2011
  • Brad Chapman Dec 07, 2011
    what has to be removed to get the brushes out? they seem to be in there awfully tight and I don't want to break them or part of the housing.
SOURCE:
How to change a climate control switch on a 2004 pontiac grand prix fan want cut off
It's not the climate control. It's the variable speed fan control. Not uncommon problem. Replace the controller. See this post
Blower motor wont shut off Ricks Free Auto Repair Advice
Aug 07, 2017 | Pontiac Cars & Trucks
I want to make my ryobi 16 in scroll saw to a variable speed unit but the motor must be the brush type so i need to know if it does have brushes
more than likely but if it doesn't consider this
the ceiling fan is a brushless motor and its speed is controlled by a variable rheostat and there are plenty of ac motors that are speed controlled by clipping the sine wave of the ac current that are not brush and armature motors
Talk with an accredited electrician as to electric speed controls for the types of motors
Nov 23, 2015 | Saws
What is the difference between a variable and non-variable speed sewing machine foot control?
variable foot control==the farther you push it...the faster the machine goes....
non variable....only has stop...and run....
Jun 05, 2015 | Sewing Machines
What is the variable frequency drive?
VFD is a device used for speed control of 3ph induction motors & automation process control
Mar 18, 2013 | Hitachi Variable Frequency Drive Inverter
When the router is at slower speeds, I can stop the motor when pushing wood through a bit. when I back off, the motor starts up again. Is this normal or do I have a problem with the router.
Is it a variable speed? Routers only cut at high speed, wood anyway, if it is variable speed, They must think you will be cutting something soft, I don't know, But they are like a dentist's drill, when they slow down, they don't cut, Keep that thing on high and make some dust, it should not bog down, If it does, check the brushes, if it still does, it has lost it's power and is basically shot. get a new one. Hope this helps.
Feb 27, 2011 | Porter Cable 3 1/4 Hp Bb Router
Saw has no power.
Does the motor continue to run, but the arm stops? It sounds like the set screw on the motor shaft is loose. See the exploded view at this link. It's called out as # 97 http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=5682&typeId=3475&documentId=333
Jan 13, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Spin half the speed
Hi.
Depending on the make and model, and type of washer, you may need to test and eventually replace the following parts:
On top loads:
Variable speed motor .
Motor coupler.
Transmission.
Control board.
Motor control unit (if present)
On front load :
Motor coupler.
Control board.
Motor control unit.
On top load the problem is often transmission or variable speed motor. On front load MCU or motor.
Dec 14, 2009 | Washing Machines
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Changing control switch
Sorry, but that is not going to work ,that motor is not compatible with that type switch. you would need a variable speed motor.Newer models have many more improvements, you should try one of them,much smoother cut. Good luck and please don't forget to rate this answer.Thanks.
Mar 29, 2009 | Saws
Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw Logo
224 people viewed this question
Top Bosch Saws Experts
mikenearman
Parson's Repair...
Parson's Repair...
MatchstalkMan
MatchstalkMan
Are you a Bosch Saw Expert? Answer questions, earn points and help others
