I can't log in by messenger live i get foutcode 800488ed
  • 516 Answers
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
Thank you.....
Posted on Oct 24, 2010
SOURCE:
I cant insall windows messenger in mu computer acer aspire one
Have you gone to the windows messager website and tryed to install it that way? If it wont let you download, Try installing Windows Live Messenger, or even Windows Live Messenger PLUS. If those are still not working for you, You can log onto through Meebo.com and still chat with your friends.
Jun 03, 2011 | Windows Live Messenger
Delete live chat?
  1. Open Windows Live Messenger window (sign into Messenger if you haven’t do so).
  2. Press Alt key to reveal menu bar, then click on Tools and select Options. It’s also possible to click on Show menu icon after the “Search contacts or the web” box. Alternatively, click on the logged on contact’s name on the top of the Messenger client window, and select Options.
  3. Select General (earlier version of WLM) or Sign In (current latest version of WLM) on the left pane.
  4. Deselect and uncheck the Automatically run Windows Live Messenger when I log on to Windows check box.
  5. Click OK.
Windows Live Messenger will not start itself automatically from next system boot up. User will need to start the program manually from Start Menu.
Apr 29, 2010 | Microsoft Internet Explorer 8
Can not log on to windows live messanger
Hello.
Are you trying to log-on to the messenger on the PC or mobile?
Mar 08, 2010 | Microsoft Windows Live Messanger
Last night I had a message box pop up when I tried to log in to msn messenger,saying that I had to update to the latest version,although I tried to ignore it and log on I was unable to continue. So I have...
What I would do is go to control panel and click on the firewall and see if it is stopping you. If that does not work I would contact the Live IT sipport and see if it is on their end. Thank you for using Fixya
Nov 06, 2009 | Microsoft Computers & Internet
Windows live messenger invitations wont go away
Completely exit Live Messenger and then delete all contents of %USERPROFILE%\AppData\Local\Microsoft\Windows Live Contacts folder.
Start Live Messenger again.
Oct 25, 2009 | Microsoft Windows Live Messanger
I have a problem with windows live messenger i cant log in
Remove the Windows Live Messenger from the Control Panel, Add Remove Programs including the utilities associated with your live messenger.
Then try reinstalling the Windows Live Messneger from this site
www.microsoft.com/downloads then search for Windows Live Messenger
Hope this woould help
Aug 11, 2009 | Microsoft Windows XP Home Edition
All my contacts are missing from my contact list
This is what MS told me to do..but did not work. Finally they told me to use 8.5. Try if it helps you.
Messenger Connectivity Log & Contacts Log
A. Delete the old log files.
Right-click the Start button and then click Explore. In the window that opens, click Folder Options on the Tools menu. Click the View tab, and then make sure that Show Hidden files and folders option is selected.
1. Click Start, click Run, type %userprofile%\Local Settings\, and then click OK.
2. Double-click the Application Data folder, double-click Microsoft, and then double-click Messenger.
3. In the Messenger folder, look for the MsnMsgr.txt file and delete it.
Note: If you get an error stating that you cannot delete MsnMsgr, please make sure that Windows Live Messenger is not running on the background. To check this, open the Task Manager window and check whether the msnmsgr.exe is running on Processes. If it is, select the application and click End Process. If you are prompted, click Yes.
To open the Task Manager: Click Start and then Run. Type taskmgr.exe and click OK.
4. If you don't see the MsnMsgr.txt file, please proceed to step B to enable the connection logging.
B. Turn on connection logging if the feature is not yet enabled.
1. Start Windows Live Messenger but do not sign in.
2. On the Tools menu, click Options.
3. In the left navigation bar, click Connection.
4. Click Advanced Settings.
5. Under Connection Logging, make sure that the Save a log of my server connections to help troubleshoot connection problems check box is selected.
6. Click OK.
C. Try to sign in to Windows Live Messenger again to replicate the error or issue being encountered with the service. A new connectivity log file, MSNMsgr.txt, is created the moment a sign in attempt to the service is made. When errors or issues are encountered, the connection logging feature will capture their logs.
D. Access the newly generated MsnMSgr.txt by following the steps in step A. Please look also for the ContactsLog.txt file. Please attach the files on your e-mail response to us.
Copy of the Windows Live Contacts folder
The Windows Live Contacts folder can be accessed on this path:
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts
Note: Windows Logon name is the logon name that you use to sign in to Windows.
Right-click the Windows Live Contacts, select Send To, and then select Compressed (zipped) Folder. A compressed file is created in the same folder. Please upload the file to Windows Live SkyDrive and we will retrieve the file from there.
To access Windows Live SkyDrive, please do these:
  1. Open your Internet browser and visit http://skydrive.live.com.
  2. Sign in using your Messenger ID and password.
  3. Click on the Public folder.
  4. Click Add files and locate the zipped Windows Live Contacts folder. Upload it.
  5. Once the file is successfully uploaded, please send us the URL or link on your e-mail response so we can download it.
While we are working on this issue, we suggest that you temporarily use the earlier version of Windows Live Messenger (v8.5) so you can continue to communicate with your friends. Please note that to be able to install the previous version, you need to uninstall all the Windows Live Essentials programs (i.e. version 2009 of Messenger, Mail, Photo Gallery, etc.).
1. Exit Windows Live Messenger.
2. Click Start, click Run, type appwiz.cpl and press Enter
3. On the Add or Remove Programs window, click on Windows Live Essentials, and then click Uninstall/Change
4. Select Uninstall, click Continue.
5. Under Select the programs you want to uninstall, check all the Windows Live programs shown and then click Continue.
Windows Live Messenger 8.5 can be downloaded from:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
Apr 29, 2009 | Microsoft Windows Live Messanger
IM keeps logging me out.
2. Type "regedit"
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope this helps
Chris (ziraffa)
Nov 11, 2008 | Microsoft Windows Live Messanger
Windows Live Messenger Error 80004005
To fix Windows Live Messenger error 80004005, you have to reinstall the latest version of Windows Live Messenger From here - http://get.live.com/messenger/overview
In case you are curious, the cause of this error is the Microsoft .NET Passport account is blocked by the .NET Messenger Service because your computer may be running a non Microsoft program that is not licensed by Microsoft this is a violation of the MSN Messenger Terms of Use.
Error 80004005 was originally created by MSN Messenger maintenance procedures. In order to stop users from using non Microsoft add-on's, that may harm Microsoft's service.
Have a good day.
Nov 10, 2008 | Microsoft Windows Live Messanger
Open Questions:
;kjnxm AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 20, 2019 | Amazon Computers & Internet
xxjml Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
&&& AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems.
Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9]*^ USA how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Computers & Internet Logo
971 people viewed this question
Ekse
Alun Cox
