Question about Hobart Dishwashers
Commercial Hobart dishwasher
Unit is a model LX30. Pump works when turned on, unit does not drain or let water in. in controller board area the left hand fuse { 3A} blows when turned on the pump works but does not do antthing else. A servive wrench comesup and initially it starts with an H on the screen. I talked with a Hobart tech. I unhooked all of the components and the left fuse still blew. He suggested to replace the relay board. I ordered the board and replaced it. It still blew the fuse. I ordered the main board after talking with the tech again and with the same results and $600 worth of boards I'm back to square 1. One hint in the back of my mind is the relay board was shelf worn and had been in and out of the package a number of times.
Any help?
    Scholar:
  • 68 Answers
I can't imagine a bad relay board would blow a fuse. The relay board would need to make a bad connection to ground to blow a fuse -- I don't see it.
If you could supply me with the ML#, I'll take a look at the wiring diagram and give you an educated answer.
Not that I recall clearly which fuse is for the drain solenoid, but the two sound related. If a drain valve is obstructed by debris, it will heat up the coil and short it out. I don't know the spec'd ohms, but I would suspect at least 50. I'd check it.
Posted on Jun 10, 2008
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Sep 04, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Jun 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Aug 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart Dishwasher
Either the drain body is stuck or the solenoid is bad,give me a little more detail,model of the unit lx18,lx30,lx40,lxi?
Jul 04, 2008 | Dishwashers
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LT 1 dishwasher leaving film on dishes
The machine is seldom the cause of "film". Make sure the unit is draining proper and that the fresh water supply is supplying good pressure.
Usually film is caused by using residential soap in a commercial unit. The commercial unit cycle is too short for residential soaps to dissolve and work properly. So soap ends up in your rinse water.
Mar 23, 2008 | Dishwashers
Hobart lx30 won't turn on
Is the circuit breaker on?Open the door and look on the right and left side at the top.you will see 2 screws,remove them and slide the drawer out.you will see 2 boards the one on the left has 2 fuses,make sure their good.let me know.
Mar 01, 2008 | Dishwashers
Dishwashers Logo
290 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
