Question about LG 42PG20 42 in. Plasma HDTV
I HAVE A LG 42PG20 TV BUT NO SCREW TO MOUNT THE TV ON THE BASE STAND WHAT SCEWS DO I NEED
SOURCE:
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
SOURCE: Olevia 227V lcd
Put the saw away. Go find a Phillips screwdriver.
My set had 16 screws - 4 columns of 4 - on the back of the unit, just above the base stand. These screws are pretty long (about 3"). I removed all 16 of these screws and the base slipped right out.
It took me a while to figure it out. 16 screws seemed excessive, but that's the deal.
Posted on Oct 12, 2008
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
Posted on Jun 19, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
SOURCE: I am trying to wall mount my LG M197WDP - PZ 19
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
Posted on Jan 08, 2010
How to disengage the stand from an LG 42PC5D
There are two pegs that protrude from the base into the tv.......there will be two large philips screws on each. remove and pull strait up off the base........hope this helps!
Jun 06, 2010 | LG 42PC5DC 42 in. Plasma HDTV
42PG20 42 in. HDTV Plasma TV: i have an lg plasma tv - 42pg20 when i turn o...
There are several known issues that can cause that.
The top candidate is the main board, the next is the Y-Main board.
Here's a link for repairing the power supply board of LG 42PG20, which also contains a link to how to test your own board to see if it is good or not:
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
Hope this helps!
May 17, 2010 | LG 42PG20 42 in. Plasma HDTV
How do i remove base stand on an lg 50pc65 tv to get it wall mounted
you have 3 philips head screws in the base, unscrew this and wil be abel to get it wall mounted after that.
Feb 14, 2010 | LG Televison & Video
I am trying to mount my LG 37" on the wall and cannot figure out how to remove the stand that came with the tv
37LG30 - loosened the 4 screws on the back of the TV but base mount wouldn't come off. Found that had to remove the screws even though already loose so that doesn't bind in the holes. Did this by making the loose screws bind in the wholes. Using twisers in the whole would have done the same thing. o
Dec 27, 2009 | LG 37LG30 37 in. LCD HDTV
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Apr 08, 2009 | Televison & Video
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
LG 42PG20 42 in. Plasma HDTV Logo
196 people viewed this question
Ekse
