Question about Kenmore Dryers
Dryer will not turn on - purchased a new starter botton, installed it as directed and still does not turn on and yes I had it plugged in, the door was closed tight and the timmer knob was turned on to a dry cycle
    Sergeant:
  • 239 Answers
Most common problem is thermo fuse, pull back off look for white fuse by blower, test with meter
Posted on Oct 24, 2010
SOURCE:
My starter botton won't work on my cabrio dryer
u need to ometer test the push start button , the thermo fuses and thermostats, of course u have already checked the electrical plug for power? test also to see if it is getting 220 at the cuicut and back of applaince
Apr 27, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Ive just installed a new door kit onto my fisher and paykel de45f56a dryer. It has never had a door as it was cracked when purchased so the dryer has never been started. I have now fitted the door however...
yes, double check the switch first. it sounds like the motor is not even moving, since the dryer was never used before sometimes there is a "tab" or locking mechanism to keep the tumbler form moving during shipping.
Mar 27, 2017 | Dryers
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 series gas dryer - motor not running
Trace the wiring all the way to the motor through the door switch, timer, etc. Also do this test: If you hear the motor hum (even a little bit) but not run, your starter switch on the motor is fried. This is a replaceable item. (This switch also turns on the heating element.) . Dryers have the peculiar problem with corroded contacts in gang plugs or other plugs. Best thing you could do is unplug and plug them several times then smather some contact grease on each contact. This will eliminate this pesky problem in the future.
Nov 25, 2009 | Kenmore Dryers
Dryer turns on when botton held down
Motor has a "Run" winding centrifugal switch that may need to be replaced. Start button energizes the starter winding but when the "run" switch fails the motor won't keep running. Switch is easily replaced without taking motor apart.
Aug 12, 2009 | Kenmore Dryers
Whirlpool dryer LER5636PQ0 push to start keeps failing to work
You could have a worn door switch . Push in on the plastic piece which closing the door actuates and press the start botton . If it starts ,several times , then replace the door switch . Pt # 3406107 . Do this after you put the 2 thermal fuse (slim white piece with 2 wires attached )wires togather for testing purposes only . BE sure to unplug dryer before doing ANY repair testing first ! If it starts by jumping the wires , then pt # 3392519 fot thermal fuse .
Jul 14, 2009 | Whirlpool Dryers
Starting botton does not work
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 25, 2009 | Whirlpool Dryers
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
Broke start button
Look inside door and get the model number for me. Replacing the start switch is easy. From back cover inside the top control panel. Let me know, Thanks Sea Breeze
Mar 20, 2009 | GE Dryers
Using 4 wire plug on 3 wire dryer
YES TAKE THE GROUND WIRE OF THE NEW PLUG AND CONNECT IT TO THE FRAME OF THE DRYER UNDER AN EXISTING SCREW OR USE A SELF TAPPING SCREW THE FOUR WIRE SYSTEM WAS PUT INTO THE CODE MOSTLY TO INSURE GOOD GROUNDING ON MOBILE HOMES AND THE METHOD WILL WOKE FINE AS I HAVE GIVEN YOU
Nov 16, 2008 | GE Dryers
Dryers Logo
41 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
