Question about Whirlpool GR673LXSS - Stainless Steel Electric Kitchen Range
Trouble code F6E4(LOST COMMUNICATION) code is on
Hi I have code u2103 on my Saab and it as lost all low power it was in limp mode with ear before and iv cleaned egr and inlet out and removed swell flaps now it coming up with u2103 can you help me please
What year an model SAAB ? U - codes are communication network trouble codes . All the control modules , PCM/ECM - BCM , ABS , air bag etc... all share info on this serial data communication net work . When a module goes off line or wiring problems set these type codes . Your best bet , take it to a qualified repair shop.
Apr 06, 2018 | Saab Cars & Trucks
Have codes on my 2005 dodge magnum two of them i am very worried about can someone explain what they mean U0126-P0700?
Definition of Diagnostic Trouble Code P0700 Category: Powertrain Definition: Transmission Control System (MIL Request)Note: This definition of P0700 is applied to all manufacturers
Definition of Diagnostic Trouble Code U0126 Category: Network Definition: Lost Communication With Steering Angle Sensor ModuleNote: This definition of U0126 is applied to all manufacturers
Jul 15, 2015 | Dodge Cars & Trucks
What does the code u0155 mean on 2008 mazda3?
DTC Number U0155 Diagnostic Trouble Code Lost Communication With Instrument Panel Cluster (IPC) Control Module
Nov 28, 2014 | 2008 Mazda 3
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
U2105 lost communication with ecm car wont start. could there be anything causing this other than ecm
If you are getting the fault code saying that it lost communication with the ECM there could be something faulty going on with your ECU. This usually will not cause the car to not start, and will make your engine run strange or cut off while running. There can most definitely be something wrong with another component in the vehicle that would cause it to not start properly.
Oct 17, 2013 | Roadi Rdt61 OBD2 Diagnostic Trouble Code...
Trouble code u1000 on nissan titan
DTC (Diagnostic Trouble Code) U1000 is a problem with the CAN communication line.
CAN (Controller Area Network) is a serial communication line for real time application. It is an on-vehicle multiplex communication line with high data communication speed and excellent error detection ability. Many electronic control units are equipped onto a vehicle, and each control unit shares information and links with other control units during operation
This DTC sets under the following conditions:
The ECM (Engine Control Module) has lost communications with one or more of the onboard control units for a specified amount of time.
To diagnose this code you must scan all the other modules to see if they can communicate with the scanner. If all the modules are able to communicate with the scanner then the problem is intermittent and can be very hard to find. If you have one or more modules that fail to communicate then the problem is the data line to that (those) module(s).
Dec 19, 2010 | 2005 Nissan Titan
Code: U0140-LOST COMMUNICATION WITH BODY CONTROL MODULE What does this mean?
U0140 Lost Communication With Body Control Module
This generic "U" trouble code applies to all car makers and indicates a problem between the PCM and the body control module. This is likely the result of a problem in the data link between the two modules.
Is the U0140-LOST COMMUNICATION WITH BODY CONTROL MODULE also set?
YES: Follow the diagnostics for U0140-LOST COMMUNICATION WITH BODY CONTROL MODULE
Perform the POWERTRAIN VERIFICATION TEST. See: Verification Tests\Powertrain Verification Test
NO: Replace and program the Powertrain Control Module.
Good luck.
Aug 24, 2010 | Jeep Liberty Cars & Trucks
I am getting a ERR F6E4 lost communications error. Can I fix this myself or should I call service? Thx in advance
HI. This will, generally, require you to replace the entire main control board. Follow the steps below to confirm the damage.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
NOTE_ This repair is not a easy task. It will require you to totally disassemble the entire control panel. If you are not comfortable with this type of repair, i suggest to contact your nearest service tech.
Dec 07, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Aid gas range error code "F6E4 lost communications"; oven not turning on
i had some milk boil over and got this error message on our oven. we had a tech come out and he said that we would have to replace a control board for $280. he went away to order the part and in the mean time i had to shut off power to some circuits and when i turned the power to the over back on it worked fine. i would try this before replacing the part
May 22, 2009 | KitchenAid Kitchen Ranges
Whirlpool GR673LXSS - Stainless Steel Electric Kitchen Range Logo
839 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
