Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer made a humming sound for a day or two, then quit working.
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
FRT17L3FW Humming Noise
You can replace the relay yourself at a fraction of the cost. It just plugs onto the compressor. Here is the relay to order.
Dec 01, 2012 | Frigidaire Refrigerators
Hums seconds only does not freeze
If it hums then quits and hums and quits and just keeps doing this then either the compressor start relay is burned out or the compressor is seized. Unless you are capable of diagnosing this you should have a tech check it out. If it's just a relay they are relatively cheap, but if it's the compressor it could cost more than the freezer is worth.
Dec 03, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Electronic controls at 0
Did it quit cooling also? Where is the humming coming from?
Nov 24, 2011 | Amana ARB2217CSR Bottom Freezer...
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
My fan in my freezer makes a humming sound
it;s best to replace the fan / or find why the noise . it will probably stop due to this problem. and you may loose food . noises generaly are the first clues . and like i'v said before . if you can hear it it's running . but if your cant it may have quit . . then not cool and food loss . **** / hope this helped mm / feed back pls .
Jan 16, 2010 | GE Hotpoint Top-Freezer Refrigerator
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
