Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
I have a ten year old laars lite 2 LD 400000 heater. It will start but then the flame goes our after 30 seconds. I have checked water circulations and is OK. What could be wrong?
    Top Expert:
  • Jandy Master
  • 10,321 Answers
Clean flame sensor
Posted on Mar 05, 2016
4 Suggested Answers
SOURCE:
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
flacooo1
  • 172 Answers
SOURCE: Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Posted on Jun 15, 2009
john224
  • 1378 Answers
SOURCE: Laars lite 2 ld will
Thank you for posting your question here on Fixya.com.
First you will need to get a hold of a digital or analog multimeter and set it for the lowest range of Ohms you can. Your safety circuit is a string of several switches all strung together in a row with the gas valve at the end and the beginning of said string. Any one switch being open or a bad connection anywhere in the circuit and the heater will not fire.
You task is to remove one end of the circuit from the valves TH or TT post and put one end of you meter on that wire and the other end on the TH/PP terminal. It will likely read infinite resistance. Leave one meter lead where it is and remove the other. Follow the circuit from the connected lead up to the first switch. Check continuity from the lead left connected to both sides of the switch. If there is continuity to both sides the switch is fine. Keep moving from switch to switch until you find the bad switch or connection. There may be more than one. When the circuit is working properly and there is nothing within the heater to cause it to shut off you should have 5 ohms or less across the entire circuit. Once you get the reading to that level the heater will work as it should
If you are not familiar with the process I described you would be better served hiring a pool technician to perform this repair as you can cause significant damage to the heater if you do not repair it properly.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 19, 2011
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Swimming pool heater
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Larrs lite low knox ten years old fires for seven seconds.three times than goes into ignition lockdown.new fire sensor installed didn't solve the problem. gas flow adequate, could it be bad gas valve? ...
Are you sure that the flame sensor is installed correctly? If the flame comes on and the flame sensor is right in the flame, then the control module is not working right. It's not 'seeing' the flame sensor input. You can prove it by jumper across the contact wires on the flame sensor. If it stays lit when you jump out the sensor, it's not working. The flame sensor tip needs to be right in the pilot flame to sense heat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 29, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Jun 23, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
100 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Anthony Davis
Anthony Davis
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
