Question about Toro Lawn Mower With Toro Power Tools
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i turn the key
    Master:
  • 969 Answers
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Posted on Nov 07, 2010
SOURCE:
Toro 74330 ztr wiring diagram
Could be several things. Starter sol hooked up wrong, key switch bad... well ok thats pretty much it, check those things then see what happens.
Dec 09, 2013 | Toro Lawnmower 20099 Mower Mowers Lawn
TORO LX 425 MOWER - STARTS AUTOMATICALLY
by trying to start it so many times sounds like you blew the fuse. your problem sounds like it started with a bad solenoid.take it off and test. if it is bad replace it. put a new fuse in and it should start as it is supposed to.
Mar 08, 2017 | Toro Lawn Mower With Toro Power Tools
Ridding mower not charging battery
Get a v12-Volt test meter and check your battery for 12+ volts not running. Then start the engine (you can jump with auto) and check voltage to see if it is higher 13-14-Volts.
The battery's available tend to be poor quality and is not unusual to have a new one fail. (new being 8 months or less)
Any further questions feel free to ask.
Nov 24, 2010 | Toro Garden
Battery goes dead over night
First thing to do is find out if it's the battery or the mower. Disconnect the battery and leave it overnight. If it's dead in the morning, you need a new battery. If not, you either have a charging problem (not likely if the battery isn't dead after using the mower) or you have a current drain.
Oct 22, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
Engine wont start just get a click
Charge you battery or get a new one and you will click no more!!!!
Apr 07, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Sep 07, 2009 | Toro Lawn Mower With Toro Power Tools
2007 Toro LX 425 Riding Mower, slow cranking.
check the starter see if it is going bad or not?
Apr 18, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
197 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
roeb
Are you a Toro Garden Expert? Answer questions, earn points and help others
