I was told to look in start up allprograms for teamviewer but it wasn't there also check my computer program files it wasn't there either so if i could i would like to get it installed
    Brigadier General:
  • 7,191 Answers
Kindly let me know whether you have installed TeamViewer or you were just running the TeamViewer program without installing.
TeamViewer program has two options:
(i)Install &
(ii)Run ( program can be used without installing)
Assuming that you have installed TeamViewer and using Windows XP operating system, to bring the Teamviewer icon on the desktop:
1) Click on Start button, then All Programs> TeamViewer > right-click on TeamViewer 5 and select "Send to Desktop" from the menu.
2) Alternately, open "My Computer", then C:\Program Files> TeamViewer > Version 5> right-click on TeamViewer.exe and select "Send to Desktop" from the menu.
If you have not installed the TeamViewer program and were using "Run" option, you will have to re-install the program.
Hope this solves your problem. Thanks for using FixYa
Posted on Mar 16, 2011
SOURCE:
Start button in windows 10 is showing critical error please help!!!!!!
do a recovery and go back to your old OS . windows 10 has bugs still .
Sep 09, 2015 | Computers & Internet
Computer may be hacked or have a virus
Most peoples computers are filled with viruses and trojans. I delete the problem files manually using spynomore to point the way (free to use pay to remove) I unhide hidden folders and system files and use the registry to remove the bad stuff. Sometimes a severe rootkit is too much to remove and it requires a reinstall of windows, that is why i use unhackme and spynomore so that i know the moment i am infected and can do a system restore if necessary. But system restores only go back about 5 or 6 days. It may be too late if you have a rootkit already. To have me teamview you to remove your trojans for free contact me at mikadot at hotmail dot com you'll need to install teamviewer to do that I would need the ID and password
Nov 27, 2013 | Dell J819K Bracket Hard Drive Desk Top 960...
Teamviewer 8 Trial version *expired* (Acer)
Here's another solution:
These are instructions for Teamviewer users that have had their Teamviewer trial version expire. This is mostly due to choosing "Commercial" instead of "Personal" when installing.
Steps:
1. Uninstall your Teamviewer:
Go to Start>All Programs>Teamviewer8>Uninstall Teamviewer 8. Follow through with the uninstall application.
2. Change Names on computer:
For Windows XP users:
a. Go to Start>Control Panel>System>Computer Name. Enter a different name in the "Computer Description Box." (your computer may not have a description at all. In this case, just enter in a name that you for sure have never used before.) At the bottom you will see "To rename this computer or join a domain, click Change." Click the "Change" button. Under "Computer name:", enter a different computer name that is no longer than 8 characters. Click "OK." It will prompt you to restart your computer, TAKE CARE TO NOT RESTART YOUR COMPUTER OR YOU WILL HAVE TO RESTART THE PROCESS!
b. Now, go back to Start>Control Panel>User Accounts>Change an Account>Computer Administrator (with name of your account)>Change my name. Change the name to a new name. Click "Change Name." AGAIN, DO NOT RESTART YOUR COMPUTER AT THIS POINT!
c. Disconnect your computer from the internet. (If you already know how to disconnect from the internet then skip the rest of step "c.") Now again go back to Start>Control Panel>System>Hardware>Device Manager Look for the "Network Adapters" tab. Click the "+" sign next to "Network Adapters." You will have to temporarily disable every driver listed under here. So, right click on the driver, click disable. Do this for every driver listed under "Network Adapters." You may now restart your computer.
d. If you haven't restarted your computer yet by this point, restart it.
e. Restinall Teamviewer. During the installation process, SELECT PERSONAL, NOT COMMERCIAL!!!
f. Reconnect to the internet. If you did the driver disabling option, go back into Start>Control Panel>System>Hardware>Device Manager, right click the disabled drivers and enable all of them. Otherwise, just reconnect to the internet.
g. After the installation of teamviewer and reconnecting to the internet, you may now try to use Teamviewer again. You'll know if it was successful if you see a different number under "Your ID." You should now be able to use Teamviewer again.
For Windows Vista, 7, and 8 users:
a. Go to Start>Control Panel>System and Maintenance (may say System Security)>System>Advanced System Settings. Enter a different name in the "Computer Description Box." (your computer may not have a description at all. In this case, just enter in a name that you for sure have never used before.) At the bottom you will see "To rename this computer or change it's domain or workgroup, click Change." Click the "Change" button. Under "Computer name:", enter a different computer name. Click "OK." It will prompt you to restart your computer, TAKE CARE TO NOT RESTART YOUR COMPUTER OR YOU WILL HAVE TO RESTART THE PROCESS!
b. Now, go back to Start>Control Panel>User Accounts and Family Safety>User Accounts>Change your Account Name. Change the name to a new name. Click "Change Name." AGAIN, DO NOT RESTART YOUR COMPUTER AT THIS POINT!
c. Disconnect your computer from the internet. (If you already know how to disconnect from the internet then skip the rest of step "c.") Now again go back to Start>Control Panel>System and Security (Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link. Simply click on Device Manager)>Device Manager. Look for the "Network Adapters" tab. Click the "+" sign next to "Network Adapters." You will have to temporarily disable every driver listed under here. So, right click on the driver, click disable. Do this for every driver listed under "Network Adapters." You may now restart your computer.
e. Reinstall Teamviewer. During the installation process, SELECT PERSONAL, NOT COMMERCIAL!!!
f. Reconnect to the Internet. If you did the driver disabling option, go back into your Device Manager, right click the disabled drivers and enable all of them. Otherwise, just reconnect to the internet.
Jun 28, 2013 | Computers & Internet
Personal account files and internet settings all deleted or suspended! Please help?
What OS are you using ? Ask here for help. I can assist you through Teamviewer. Free of charge... don't worry
Oct 25, 2012 | HP Mini 110-1037NR Netbook
I am using teamviewer version 6 on windows 7 computer. When I open teamviewer the message says lan only connection. When I click the connect button. The program does nothing for 2 minutes then a message...
You can try opening port 5938 on your router to see if this opens up a connection for you. If that doesn't work I would recommend going to their website and opening up a ticket to see if they can solve your problem for you.
Feb 20, 2011 | TeamViewer
OS X will not allow copy and paste or move folders from anywhere
Hey hi there,
Try this.
1.Open Internet Options>Security tab and highlight the "Internet" icon, click the "Custom Level" button and under "Miscellaneous" tick "Enable" for "drag and drop or copy and paste files"
click OK/Apply/OK.
2.Go to WORD > Tools > Options > Edit
Under Cut & Paste Options check both
"Show Paste Options Button"
"Use Smart Cut & Paste"
and also delete the temperory files.
START -- RUN -- %TEMP% -- CTRL + A -- SHIFT + DEL
START -- RUN -- PREFETCH -- CTRL + A -- SHIFT + DEL
THANK YOU,
Manish Shirsikar
May 17, 2009 | Microsoft Office Word 2007 Upgrade Version...
Remote Desktop
Yes, you can do all you want by using TeamViewer. A special software program from  www.teamviewer.com  just go to the above URL and download the software and select personal/non-commercial use when you intall the software.
Best Regards
Krishan
May 11, 2009 | Computers & Internet
Need to clean hardrive on computer
click on the start button and then click run and type %temp% and you will get the folder and please delete all files inside that folder..
click on start->allprograms->accessories->system tools->diskcleanup
please follow the above steps it will solve your issue
Mar 03, 2009 | 1998 Plymouth Voyager
Toshiba Satellite 1805-S204 ...
Do a Windows Update. This will be on your Start Menu. If it isn't, thenclick on "All Programs", then "Accessories", then "System Tools". Thiswill take you to the proper page. Alternatively, try windowsupdate.microsoft.com(notnecessary with Vista). It is very important that you get all availablesecurity updates. Other updates may less critical, but are stillrecommended.
Get rid of cookies. These are the little crumbs that are left behind onyour computer after you visit a website. Click on Start>> ControlPanel>>Internet Options. The second row down will say DeleteCookies, click on that. Click on Delete Temporary file; when the littlebox comes up that says "delete offline," you don't have to click onthat. Click on Delete temporary Files.
400px-browsing_history_297.jpg magnify-clip.pngAlternatavely, download CCleaner and CleanUp! and run them both after installation. This will take care of all of your wasted space (e.g cookies, internet cache files).
  1. Complete Disk Cleanup. After clicking on "Start", move your cursoron "All Programs", then up to "Accessories", then "System Tools". Clickon "Disk Cleanup" from the list that appears. Click the "More Options"tab at the top of the page, and select all three of the following:"Windows Components," "Installed Programs," and "System Restore". Cleanup all three by clicking on their respective tabs. You may want todelete all but your most recent system restore point as you probablydon't need the others.
  2. Defragment your computer.Defragmenting your computer moves all your files to where they aresupposed to be. You may want to download an independent defragmenter(e.g. Defraggler by Piriform). It is small, concise, powerful, and much quicker than the one distributed with Windows.
  3. Remove adware, malware, and spyware. Use a search engine to find"Lavasoft AdAware 2008". This will take you to a site to download thesoftware. Download and install this program. You can also use "SpybotSearch & Destroy." SpywareBlaster is a good preventative measure to use as well. All have easy-to-follow instructions. SUPERAnti-Spyware is yet another option. For malware, MBAM is yet another option.
  4. Install anti-virus software. Kaspersky, AVG, Bitdefender, Antivir, and Avast are free for personal use.
  5. Go to My Computer. Now go to tools at the top. Folder Options...View, then check the box "Show Hidden Files and Folders" then go toLocal Disk, Documents & Settings, Your Account, and deleteeverything in: My Recent Documents, Local Settings History (Do notdelete everything in local settings, just delete everything in thehistory folder of local settings) (and while in Local Settings) Deleteeverything in temporary internet files.
    • 180px-add-or-remove-programs.jpg magnify-clip.pngRemove unwanted programs by going to start, control panel, add/remove programs, then remove unwanted programs.
    • When your computer is running in ship-shape, then go to start, allprograms, accessories, system tools, then system restore. Create arestore point, and when your computer is running poorly, restore it tothe day.
    • If you havn't cleant up your PC for a long time, you may need to clean your PC Registry with a System cleaner and Registry repair software
Jan 25, 2009 | Toshiba Satellite 1805-S204 Notebook
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
