Question about Lasko 3300 Wind Machine Fan
I cant clean my wind machine properly can you explain me how i desmantel de unit????
    New Friend:
    Problem Solver:
Show pictures how to take apart fan to clean it
Posted on Mar 25, 2011
SOURCE:
When winding bobbin the needle continues to be rngaged, s this normal
Hi Ron, I'm Julie. No it doesn't sound normal. What brand and model of sewing machine are you using, please?
Aug 04, 2015 | Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
I have a bosch fd8610 fridge, the fan inside the fridge need a good clean, how do I remove the outer housing so I can get to the fan?
Hi
I have the same problem with my fridge model FD8208
Is the same peaple with can answer how desmantel protctgrill for the fan. I must clean the fan blades. Of course first discontcted power on the fridge.
Thanks for all answer.
Jul 16, 2012 | Bosch Refrigerators
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
Saeco Vienna de luxe no coffee comes out
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
Jul 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Liquid leak while Vienna runs...but where from?
You may have a cracked coil inside the boiler and cracked nut of the coil going up to the wiring lug. Check it out, it will be a hair thin crack, almost invisible.
Feb 11, 2009 | Saeco Vienna De Luxe Espresso Machine
Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Nov 25, 2008 | Janome Memory Craft 9000 Computerized...
You can download a manual at www.cerinicoffee.com
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Noisy turntable
I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
Mar 25, 2007 | De Dietrich DME112X Microwave Oven
Lasko 3300 Wind Machine Fan Logo
2,327 people viewed this question
Top Lasko Dryers Experts
Wbix
John Danckwerts
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
