Question about NetGear FS608 Networking Switch
DHCP problem and router connection
I had 4 Computers running with a Netgear rp614 Router on my broadband internet. Then i got 3 more PC's, but the new PC's must have the same internet connection. So i bought the Netgear fs608 8-Port switch, and connected the switch to the Netgear rp614 router. Then i connected some of the PC's to the switch, and ... the DHCP didn't work.
Then i tried to acces the internet through the switch and the router with static IP's, but that didn't work, the Computers could ping each other, but not the router...
So why can't they ping the router?
Information: There is no hardware problem with the cables, the IP adresses have been in the class C network (192.168.0.0). The router did not recognize the other hosts too (Routerstate - Connected PC's)
thanks in advance
Fuxi
  • Felix Degen Jun 10, 2008
    It was a "beginner failure", i used normal Ethernet cables to connect the 2 switches, i have to use a crossover cable :-).
    So it has nothing to do with DHCP or so on, just not crossed...
    So... problem fixed :-)
    mfg.
    Fuxi
  • Vakhtang Assatrian May 11, 2010
    Does the router assigned IP to PC's via DHCP? Can you see router IP in the APR cache of computers?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
From the above configuration, please check if you can now access the Internet.
Posted on Aug 16, 2009
    Scholar:
  • 148 Answers
  • access 198.162.0.1 router's configuration page and set the settings IP addressing to DHCP or auto assigning the IP addresses and the DNS
  • set the router mac address to the middle option set to computer mac address
  • and make sure all the computers connected to the router and the switch is set to automatically detect the IP address and the DNS is all set to auto detect...
  • how to access XP...goto to control panel and select network connections (for vista network and sharing center, manage network connections) and right click on the LAN, select properties select tcp/ip and click properties. and selct automatically assigns IP address and DNS.
Posted on Jul 19, 2009
Netgear rp614v4 as a switch
This router acts like a switch automatically, you can converse between ports on the same LAN connections without any setup.
They all need to have the same network setup, the same gateway address and DHCP setup.
If you are not accessing the internet that's all you need.
See manual http://downloads.netgear.com/pub/netgear/files/RP614v4_RM_12Jun08.pdf
Apr 02, 2014 | NetGear RP614 4 Port Cable/DSL Router with...
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I am trying to install a Netgear router after my switch. I end up having no internet on some of the computers connected to the hub and none on the router. If I configure the router as a dhcp client...
You'll want to configure your router as a dhcp server. Connect the switch to your router's lan port. Connect the remaining devices to a port on the switch. Your wireless access point should have it's dhcp server disabled. You can only have one dhcp server per network. The wireless can get it's address from the router's dhcp and the wireless client devices will get their ip address from the router, as well. If your wireless access point is a router with a wan/broadband port and some switch ports you will want to make sure that you are connecting to your Asus switch via one of the switch ports.
Be sure that your client devices are configured to get their ip address via dhcp and you should be surfing the interweb in no time flat.
Oct 21, 2010 | ASUS GX1008B 10100Mbps Desktop Unmanaged...
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Netgear Rp614 router is not supported on my windows vista 64 bit os. How can I get it to work?
Hi, follow the steps below to reset and reconfigure your RP614:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://192.168.0.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 29, 2009 | NetGear RP614 Router
Router wont connect to internet
b. Connect to the router by typing http://192.168.1.1 or http://192.168.0.1 in the address field and click Enter or Return key.
4. Power cycle.
Apr 26, 2009 | NetGear -DSL Web Safe Router/ RP614 -...
How do I set a new address in the 850 motorola router
First, you ned to login into your router (check the manuals for this, Netgear has this printed behind the router near Serial no. etc).
Enable DHCP settings, allocate IP-address range say 192.168.0.1 to 192.168.0.5 (enough for 5 computers connecting via this router). Next, configure each computer to accept new IP-address from router by enabling DHCP.
The settings on a Windows XP Professional Desktop:
Need administrator access to your desktop, right-click on Network icon, Internet Protocol TCP/IP Properties, click on Properties button, then select Advanced properties, you can set DHCP from here.
Dec 17, 2008 | Arris Wireless G Broadband Router (wr850g)
Netgear MR314
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at
the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network.
Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other
end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a
standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical
outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result
in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each
other across a network, such as the Internet.
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router.
The next few pages tell you, step by step, how to configure your network settings based on the type of Windows
operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network
adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart
your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area
Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the
OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the
Classic interface (where the icons and menus look like previous Windows versions), please follow the
instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon.
Then click the Network Connections icon.
click the Properties button.
button. Click the OK button again to complete the PC configuration.
Jul 05, 2008 | NetGear MR314 802.11b
Net Gear Router
You should be able to get into your routers settings by typing in it's IP address in your internet browser, eg 192.168.2.1 or something similair. assuming you are connecting via an RJ45 Lan vable as you don't mention wireless, when in the routers settings look for the DHCP settings, this should be automatic so as to assign your pc an IP addresss automatically. When you connected your modem to the router, this should have been set up automatically as is usual with cable, so if still no connection go to your network cards properties in Control Panel>Network Connections, right click>properties>TCP/IP line>properties and ensure obtain IP address automaticcaly is ticked and click OK. Go to your Internet browser>internet options, then click the connections tab and make sur that 'Never Dial a Connection' is ticked. Restart your pc and try to connect to the internet.
Mar 25, 2007 | NetGear : RP614 4-Port Cable/DSL Router...
Macintoshes and the RP614 Router Gateway
You need a Macintosh computer running MacOS 8.6, 9.x, or 10.x. (Netgear products are not supported for versions of MacOS before 8.6.) You can use the RP614 with an eMac, iBook, iMac, PowerBook, PowerMac, or PowerPC as long as they are running one of these versions of MacOS. You also need a few Ethernet cables to make the connections between the router to your modem for internet connection and from the router to your computers or peripherals. Topic 2. How do I prevent my Network configuration from being lost when I restart my computer? When making configuration changes for MacOS it is best to use Configurations (MacOS 8.x or 9. x) or Network Location (MacOS 10. x) settings instead of just changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). If you just make changes to your settings, they may be lost when you restart your computer unless you have saved them in a Configuration or Network Location. To create a Configuration in MacOS 8.x or 9.x: 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. From the pull-down File menu select the Configurations option. 3. Choose New Configuration. 4. Type in a name for your new configuration (Netgear Router). 5. Make your changes to the AppleTalk (or TCP/IP) settings. 6. When you close AppleTalk (or TCP/IP) choose Save Changes. Whenever you make Configuration changes for settings in MacOS 8.x or 9.x, open Configurations from the File menu or by pressing Command-K. Saving your changes in Configurations means that they will not be lost when you reboot your computer. To create a Network Location in MacOS 10.x: 1. Open the Apple Menu by clicking on the Apple icon in the upper left-hand corner of the screen. 2. Select System Preferences. The System Preferences window displays. 3. From the System Preferences window click Network under Internet & Network. The Network settings window displays. 4. Click the Lock icon (if necessary) in the lower left-hand corner of the window to unlock the Network window so you can make changes. (You may be asked to type in your User Name and Password.) 5. Click the pull-down menu next to Location at the top of the Network window. 6. Select the New Location option. 7. Type in a name for your new Location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left-hand corner to prevent further changes. The Apply configuration changes? Window displays. 10. Click Apply to apply the configuration changes for the newly-created Location. 11. Close the Network window. Topic 3. How do I connect a Macintosh to the RP614 Router Gateway? MacOS 8.6, 9.x, and 10.x 1. Set up your system for installation. 2. First make sure your ISP connection is working. Try testing your computer with the ISP directly to make sure you can successfully make a connection to the internet. 3. Connect your DSL or cable modem to the Netgear Router. 4. Log on as Administrator (if required for your system to make configuration changes). 5. Quit all other applications. It's best when configuring MacOS 8.6 and 9.x to use the Configurations settings for AppleTalk and TCP/IP because they should then retain their settings when you reboot. (Use Network Locations to save your settings changes in Mac OS 10.x.) If you just change the settings but don't use a Configuration or Network Location to save your settings changes, you may lose those changes when you restart your computer.
Feb 19, 2006 | NetGear RP614 Router
NetGear FS608 Networking Switch Logo
848 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
