My computer i think crashed, i can get on safe mode with networking with limited programs, but when i try to start my computer normally it just goes to a blue screen and wont do anything else..what can i do to be able to start my computer normally again??
  • 11,800 Answers
Windows crashes because an very important program has been corrupted. The best way to fix that (since you have no idea which program) is to recover your files in Safe Mode then reinstall Windows - and make sure that the normal format option (not the fast one) is selected during process.
Posted on Oct 24, 2010
SOURCE:
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
What does starting in safe mode acconplish?
Booting in safe mode simply launches the operating system with minimal services enabled, usually no network availability, and a limited ability of usage, safe mode is used when diagnosing possible threats or for emergncy data access. In the event that the computer has stopped you from gaining access to it. A computer should never forcefully start in safe mode, it is an option usually selected on a black and white screen, start normally or start in safe mode, or start in safe mode with network. Hope this explains is a little better
Jun 14, 2014 | Microsoft Windows 7 Home Premium Operating...
Press the power button and for a fraction of a second there is power to the computer but will not start. Ibm thinkpad a22
use Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words Safe Mode appear in the corners of your monitor to identify which Windows mode you're using.
If an existing problem doesn't reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes. If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one to see if a program might be the cause of the problem.
If your computer automatically starts in safe mode without prompting, a problem with your computer might be preventing Windows from starting normally. If you think the cause of the problem might be a recently installed program or device, try using Recovery in Control Panel
Feb 15, 2011 | Computers & Internet
My Lenovo laptop starts up and shows Microsoft Windows starting to load but a few seconds later the screen goes black. The computer is on but it shows a black screen.
Try running in Safe mode.
Start the computer and hit the F8 key many times till you get Windows Advanced Option menu - Choose safe mode with or with out networking.
Does your computer seem to be working now? (safe mode is a limited use mode)
Chances are that your computer is infected and preventing normal use..
Restoring the computer would be the easiest way to fully clean out all infections and needed software corruptions. A full restore DELETES all DATA from the hard drive - Make sure you have all your data backed up. You can back up your DATA in side safe mode.
The information given relates to CORRUPTIBLE software like a virus....
Other issues may factor in to this but, not believed to be so.
Thank you for contacting Fixya.com.
Nov 11, 2010 | Computers & Internet
I have windows xp home edition and it won't load up. The windows logo comes up then it freezes up and the red light on the tower goes off. There is no way to shut down so I have to unplug it and try to...
Hello
Hold down the f8 key while starting or booting up.
Choose start up normally.Once started,Select disk cleanup from your program accessory system tools area.
Then choose disk defragment and let it run,this may take an hour or two to complete.If your using an anti virus program do a full computer scan.If not then get one AVG is free and works well for anti virus.
Last,yo may need to clean out any dust or dirt from the inside of the pc case with a vacum or a rag check the fans for proper operation.
Aug 29, 2010 | Microsoft Windows XP Home Edition
Black screen nothing loading
One of your driver is acting up. start in safe mode, disable one of the drivers (DVD or whatever) then close and try to start normally. If the PC starts then reinstall the driver.
Aug 10, 2009 | Lenovo 3000 C200 Notebook
Display driver crashes & recovers. Sometimes over and over again until computer crashes. Then I have choice of safe mode, normal etc.
restart computer at startup press f8 down for 3 secs / should give u options /go to safe mode hit it follow on sceen till u get to desk top open controll go to uninstall programs open and find the driver u put on should be display and deleat then restart should solve dave if not f8 restart try f11
May 01, 2009 | Computers & Internet
My Control Panel crashes when I switch views.
Please try to open control panel in safe mode and let me know what happens?
you can go to safe mode by tapping f8 when computer is starting up.
If safe mode works fine then any of the the start up item, third party service,spyware or useraccount is causing the problem.
To find if startup item is causing the problem we need to use the msconfig command on run and click on startup item and disable all apply close click and restart on prompt and try to open control panel on normal mode.
please let me know the safe mode status.
Aug 19, 2008 | Microsoft Windows XP Home Edition
Start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computer crashed
by unplugging the adapter has not solved your problem because the driver is the cause of the crash. Try booting in safe mode again, but this time select last known good configuration, or boot in VGA mode(when in VGA mode uninstall the driver in add/remove programmes), if you get into last known good configuration your pc is working as normal. If none of the above work you may have to use your XP cd to do a system repair, if so post back
Sep 30, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Open Questions:
Computers & Internet Logo
43 people viewed this question
Ekse
Alun Cox
