Question about Toto Washlet S400 for Power Gravity Toilets - SW564T694
How do you lower the toto power gravity float? no room to twist or push down......
4 Suggested Answers
SOURCE:
  • 49 Answers
SOURCE: Continous water running
just lower your float a little further. otherwise i'd adsume air is leaking out of your float. but if your float is up in the shut off position and water is still coming out. then you need a new assembly.
Posted on Sep 20, 2009
SOURCE: My toto power gravity siphon
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Posted on Oct 26, 2010
  • 118 Answers
SOURCE: my toto cst854 has a power gravity mechanism. the
loosen the adjustment screw on the top of the fill valve.
Posted on Dec 06, 2010
Toto one piece toilet intermitnently over fills and water runs out through the handle hole in the tank.
This sounds like an inlet valve issue, or possibly a sunk float. Replace as needed. There should be a chamber that is LOWER than the handle, that would allow water to flow down into the bowl, is this item too tall?
Mar 02, 2011 | Toto Home
The toto toilet keeps running over the overflow tube in the tank. I cleaned the valve which worked for a while but now is back to running. Should I replace the gravity valve?
If you can lift the float arm and it stops the water flow into the tank then the float arm needs to be adjusted. The proper adjustment will stop the water flow when the level is between 3/4" and 1" from the top of the overflow tube. The newer style valves have an adjustment screw that is easily located and can be adjusted without any dis-assembly.
Feb 19, 2011 | Toto Home
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Sep 14, 2009 | Toto Washlet S400 for Power Gravity...
Sep 04, 2009 | Toto Washlet S400 for Power Gravity...
My Toto keeps running
Yes, there is either a screw that can be turned lowering or raising the water level, usually found on top of the fill valve.
Or there is a lever system that raises or lowers the float, thereby raising and lowering the water level.
The first it typically found on fill valves with a float ball attatched by a metal rod to the top of the fill valve.
The second are on the "fluidmaster" type fill valves.
If you still cannot find the water level adjustment describe in detail or provide pictures of the type of fill valve you have and I will walk you through it.
Aug 16, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
Did you replace the flapper with a genuine Toto replacement flapper? If you didn't, they are slightly different. Toto toilets are fantastic but you do need to use OEM parts for repair.
Mar 13, 2009 | Toto Washlet S400 for Power Gravity...
My toto toilet keeps running
if its a metal arm connecting the ballcock shut off valve to the float flush it and bend the metal so the float is lower. if u can adjust the ball **** lower then do so. the shut off is not shutting off cause the float isnt going high enough. and the excess is going down the overflow.
Nov 29, 2008 | Home
Toto Washlet S400 for Power Gravity Toilets - SW564T694 Logo
44 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
