Question about NEC MultiSync XE17 (White) 17 in.CRT Conventional Monitor
Driver for NEC Multisync XE21
My old NEC 21 inch monitor worked beautifully with my Compaq laptop, but it will not go beyone the Windows boot screen on my Payasonic CF-29E. I am unable [probably as a result of incompetence] to find a driver. to download.
likewise, your site does not consider the XE21 to be a valid product!
Since I do get the boot screens, I know that the tube is working! What can I do to keep it on all the way into the Toughbook's boot?
Many thanks.
  • pnewcomb Jun 08, 2008
    Many thanks! I'll try to figure out what you said.....since I'm a real tyro! The Windows on this laptop is XP Home, and I've added SP 2 and anything else that has come along!
    Thanks again,
    Paul
  • Joe Shuler
    Joe Shuler May 11, 2010
    what version of windows are you running on your Panasonic?
    a general setting for older monitors is to use the refresh rate of 60hz. text mode (when the bios boots) and the default splash screen for most windows version is 640x480 which is standard vga mode. Here is the specs on your monitor:
    Model:
    MULTISYNC XE21 (JC-2131VMA)
    Max Resolution:
    1280 x 1024 75Hz
    Sync Type:
    Sync on Green, Seperate
    H Freq/ V Freq:
    31-69 Khz / 55-120 Hz
    Tube Manufacturer:
    Monitor Type:
    Multisync/Multiscan
    Tube Model:
    Tube Size:
    21
    Connector:
    HD-15
    Hope this helps.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 114 Answers
Normally if you set the refresh rate to match what the specs are (mentioed above), it should go you working.
Posted on Jun 08, 2008
'No rgb signal' to second (old) monitor
try restarting the pc in safe mode
uninstall the graphic driver restart the pc and again restart the pc
this is problem of screen resolution
Apr 10, 2014 | Dell Dimension 5150 Intel Pentium 4 w/HT...
I cannot get my HP Compaq L2105tm monitor to work unless I start the computer with another monitor, log into Windows, and then unplug the old monitor and plug the L2105tm in...
If this is on a laptop then right click on the desktop click screen resolution then hit detect and it should detect it. if not try adjusting the input on the monitor when you boot.
Feb 28, 2011 | HP L2105TM 21 inch Monitor
NEC multiSync 1700V as external monitor for Notebook Toshiba U205, Operating System Window Vista Home Premium. It displays only part (80%) of the picture compared with notebook's monitor.
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
Nov 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
LCD screen problem, two smudges
Could be a stuck pixel ... Found this on wiki - includes a video:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Hope this helps.
Sep 03, 2009 | NEC MultiSync LCD2170NX-BK - flat panel...
Screen off center
try updating the latest driver for your video and bios. try connecting your laptop to external monitor
if both of this didnt solve your problem, i suspected you lcd screen is faulty and need to replace.
May 29, 2009 | NEC MultiSync XE21 (White) 21 in.CRT...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC monitor drvier please !!
if you monitor turn on then not problem with monitor. it's related with your computer.
and what does it do when turning it on?
need more info for exact answer.
Mar 25, 2009 | NEC MultiSync FE991SB 19" CRT Monitor
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Computers & Internet Logo
299 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
