Question about Lexmark X5470 All-In-One InkJet Printer
Power supply There is power to the printer, but cannot power up the printer. Any suggestions?
    Genius:
  • 2,035 Answers
Please check if the printer is working in another power outlet............
Posted on Jun 11, 2008
  • Anand Kumar
    Anand Kumar Jun 12, 2008
    This is the problem with the power adapter you need to buy new adapter you can buy then online from Lexmark website.......
I have a Canon Pixma ip90V printer and every time the printer starts to print it shuts off; any suggestions what to do?
Sounds like it is either the power supply or the board.
Try disconnecting the power supply (unplug the printer) for about 5 minutes. Reconnect and turn it on. If this works it will probably not be a long term fix. Sounds like your in for a new printer or power supply for it soon. Did you have a electric outage recently? Or power surge?
Mar 28, 2011 | Canon PIXMA iP90v Printer
My printer does not turn on?iam pushing the on button.
Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. With the other end of the power cord still plugged in to the power outlet, the power supply of your Lexmark X5650 should have a green light on around the silver contacts. If not, you might have a defective power supply. If that's the case, I suggest you contact Lexmark Technical Support for the power supply request. If there is, plug it back in the printer all the way through and in a correct position. Printer should power on automatically, otherwise, press the power button. If printer is still not powering on, it might be defective now. Contact Lexmark Technical Support for further troubleshooting.
May 11, 2010 | Lexmark X5650 All-in-One InkJet Printer
I put a new black printer cartridge in and now it doesn't power up at all. I replaced the printer cartridge with the old printer cartridge and it still isn't powering up. I replaced the power cord,...
With the green light lit on the power box or power supply of the printer, that indicates that there is power flowing. But just to make sure it's getting enough to power the printer on, bypass any power strips or extensions, if you're using one, and plug the power cord straight to a known working power outlet. Make sure the power box or the power supply is inserted all the way in the slot and in the correct position behind the printer. Press the power button if needed. Hope this helps. If it's still not powering on, I suggest you contact Lexmark Technical Support for further assistance.
May 04, 2010 | Lexmark X4690 Wireless InkJet Printer
HP OFFICEJET 7210 all in one printer is diplaying carriage jam and check right cartridge. I have the manual and done everything suggested but still not working. the display still shows the same . anyone...
Please perform the steps provided in the following web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&cc=uk&lc=en&dlc=en&product=391153
If the issue persists, please perform:
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
If the issue persists, please replace your printer, as this is a hardware issue.
:) Dr Tony
Apr 20, 2010 | HP 7210 OfficeJet All-In-One Printer
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
All Lights Flashing
Your printer need service. Its firmware problem. All lights flashing error state usually indicates a hardware problem of your printer.
Aug 04, 2009 | HP OfficeJet D125xi InkJet Printer
My Canon MP780 will not power on.
This is what the service manual says;
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi i have mislaid my lead that goes into my printer and the electrical supply can you please help and tell me what lead i need to purchase
If lead you mean power supply, I suggest you go to a computer store as they will most likely have a possible match. Most printer power supply leads/cables have a figure 8 female plug on one end and the plug on the other. The other lead/cable is the USB printer cable which you can buy at the computer store. If your printer is small enough bring it to the store to find a good match. If not I suggest you trace the outline of the female plug on the printer and bring it to the store. Hope this helps.
Jul 25, 2008 | Lexmark Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
