Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Same problem, but no humming
I have the same issue with a Whirpool Gold top loader. When it gets to rinse, it stops and it doesn't work on the Cold Cold setting only Hot cold or higher (but still has the stop issue at rinse). Cold does not work at all.
    President:
  • 1,462 Answers
Check cold valve - possibly open circuit
Posted on Jun 19, 2008
Hi. I have a Whirlpool Gold Ultimate Care II Quiet Wash plus top loader washing machine. Today as the water went in to rinse the wash it flooded out across the floor from underneath. Is there a filter I...
No problem with Filter.
Pressure switch is not working, it is not sensing the water level. There could be one more reason can cause this issue. Please check the Pressure HOSE whether is punchered or not.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My F and P Eco Smart top loader gets to the rinse cycle then stops. An electric hum is heard, then the warning signal goes off. It wont go any further than that.
You need to unplug that machine and not use it again until you figure out the issue. I would say it sounds almost 100% like you have a bad water pump. If the pump is getting wet or has a short in the coil, it will get hot and shut down. Bail out any water that is in the tub currently, and inspect that pump ASAP. if you continue to use it like this, you risk burning out the motor controller.
Jan 07, 2011 | Fisher and Paykel IWL12 Top Load Washer
When my machine gets to its rinse cycle it works for about 30 seconds and then all the lights start flashing and it stops working
You most likely have a faulty cold inlet valve. When the machine gets into the rinse cycle, it needs to fill up with cold water.
Depending on whether you have a top loader or front loader, there may be a seperate valve for the rinse water intake on a front loader.
Let me know the make and model of your machine and I can help you identify and replace the inlet valve.
Regards
Ash
Nov 15, 2009 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Stoping before draining
make sure you have cold water unit rinse in cold water only,,even if it says warm...check the inlet vavle it should be humming in rines the cold sideof valve,,if not humming replace,,if working ok replace lid switch
Jul 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
