Question about Refrigerators
Remove dispenser bezel from kenmore 10657572791 refrigerator
  • Anonymous Mar 13, 2014
    NOT COOLING
  • 6,993 Answers
On the bottom lip of the front cover toward both the left and right side there are notches where a flat-head screwdriver fits. Twist the screwdriver while in the notch and the face should pop off.
Also, read the manual that came with the refrigerator. It has clear description on how to remove the dispenser bezel.
Good luck.
Posted on Oct 24, 2010
SOURCE:
How do you remove the panel covering the water and ice dispensers in an older Kitchen Aid 48 Superba side by side refrigerator freezer? I need to replace the water microswitch.
On the bottom of the bezel around the dispenser you will find 2 very thin slots. You push in a flat blade pocket screw driver and pry it up then lift the bezel up and off. Now look at the switch. It should have one mounting screw and a plastic pin sticking through the other mounting hole in the switch body. I'll bet that pin is broken and the switch is not making contact with the dispenser paddle. If it is broken you'll have to order that back plate . there may be nothing wrong with the switch. If the plastic pin is there, then the switch is indeed bad.
Aug 14, 2016 | Refrigerators
HOW TO TURN OFF ICEMAKER
There should be a valve for the water line that goes to the frig. Turn it water flow to the frig.
Sep 13, 2014 | Kenmore Refrigerators
How do you remove the ice dispenser bezel on the freezer door?
Usually a putty knife under the buttom of the bezel and carefully prying it out will do it. repairclinic.com has a good video on this.
Jul 28, 2014 | Refrigerators
Water dispenser not working on kenmore trio refrigerator
The tubing inside the door is most likely frozen. Mine did that a year ago. I had to remove gasket and loosen screws around edge and allow to defrost inside door. There was a lot of ice around dispenser and tubing.
Sep 16, 2012 | Kenmore TRIO® 77553 Stainless Steel Bottom...
Water dispenser lever is broken
On my FRIGIDAIRE MODEL: PLHS69EGSS side by side
1st, unplug or turn breaker off for refrig. 2nd, remove the slide out drip tray, 3rd, remove the 3 bottom screws at the bottom of the dispenser bezel (behind the drip tray). 4th, remove the bezel (slide up about 1/4" and pull forward, gently), WHEN DOING THIS BE VERY CAREFUL YOU DON'T ACCIDENTLY UNPLUG THE CONTROL BOARD FROM THE MAIN BOARD. 5th, remove the 3 screws holding the dispenser mechanism in place. 6th, remove the water dispensing hose from the dispensing mechanism., 7th, carefully unplug the power supply to the main board. hold down the clip to do this. 8th, with the dispenser out, remove the water dispenser lever plug from the coil board, 9th, remove the 2 screws for the metal hold downs for the lever pivot.
Be SURE YOU LOOK AT HOW THE SPRING IS LOADED. OTHERWISE THE LEVER WILL NOT FUNCTION PROPERLY.
chances are, you will have difficulty removing the water hose from the dispenser unit. I did. I also had a harder time trying to get it back in. The factory hose is pretty rigid and I figured there mus be a better way. I had some 1/4" clear hose from home depot. I got a piece of 1/4' tubing and made a splice from the factory tubing to the clear, flexible tubing. The flexible tubing allows you to have additional tubing to play with and makes the job much, much easier. good luck
Apr 07, 2010 | Frigidaire Professional Side By Side...
Kenmore ice dispenser front bezel removal
It snaps off. Start on one side and pry carefully with a putty knife.
Eric
Oct 09, 2009 | Refrigerators
Water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
Sep 11, 2009 | LG LRSC-26922 Side by Side Refrigerator
Remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
