Question about Vtech Cordless 6041 Phone
You can't use the phones. They say line in use. All the phones are in the cradles. Some say out of range.
  • 10,515 Answers
Few things to be considered before you troubleshoot :-
1. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. Make sure the power adapters are connected to working electrical outlets that are not controlled by a wall switch.
2. Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
3. Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
4. To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
After this follow the below tricks :-
1. Recradle the handset for 15 seconds, then lift the handset and press TALK.
2. You may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset batteries.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset batteries.
Step 5: Wait about one minute for the handsets to re-establish a link with the telephone base and then test the phone again.
NOTE: After resetting the telephone system, you will need to reset the clock. If the time is not set, you will hear Time and Day Not Set when you listen to messages.
NOTE: If you have caller ID service, the time will automatically be updated whenever caller ID information is delivered. However, since caller ID delivers the date, rather than the day, you must program the year once so the system can derive the day of the week.
To set the day and time, complete the following steps:
Step 1: Using a handset, when the phone is not in use, press MENU.
Step 2: Press ?DIR or ?CID until you see SETTINGS; then press SELECT.
Step 3: Press ?DIR or ?CID until you see >Set date/time. Next, press SELECT.
Step 4: Press ? or ?, or use the dial pad to enter the month, then press SELECT.
Step 5: Press ? or ?, or use the dial pad to enter the date, then press SELECT.
Step 6: Press ? or ?, or use the dial pad to enter the year, then press SELECT.
Step 7: Press ? or ?, or use the dial pad to enter the hour, then press SELECT.
Step 8: Press ? or ?, or use the dial pad to enter the minute, then press SELECT.
Step 9: Press ? or ? to select AM or PM; then press SELECT. You will hear a confirmation beep.
Step 10: Press and hold OFF to return to the idle screen.
3. Take the phone out of the cradle (charger). Press and hold simultaneously for more than 5 seconds the red telephone-symbol key and the # key.
You will hear a confirmation tone and DE-REGISTRATION COMPLETE appears.
Now go to the OTHER phone (the MAIN phone). Take it out of its cradle and put the deregistered second handset in the MAIN cradle. The window displays a few messages and then REGISTRATION COMPLETE.
4. Go to Menu then select System Reset, then select Replacing base, then answer Yes. This will advise you to place in base to register and it will do so in about 5 seconds
If the problem persists, it is an inner cathode relay problem. The unit has to be sent for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
SOURCE: Base handset out of range
Try opening the phone battery compartment on the back of the phone, disconnecting the battery wire, then reconnecting the battery wire. Solved my "Out of Range" problem - phone came back on and worked properly.
Posted on Nov 16, 2009
My la ndline phone has been searching for thre weeks. Is there an answer to his problem.i cannot use my phone I wish I knew what to do got clear my phone
It sounds like it's having trouble finding the cradle that you set it in to charge. Is the cradle still plugged in? Both phone line and power? If it is plugged into a phone line and the power is hooked up, it sounds like you need to return the unit.
Nov 16, 2017 | Televison & Video
Phone is displaying "out of range or no power at base." How do I fix that?
There's the charger base cradle that plugs in to the phone jack and power socket on the wall. Make sure both things are connected. The phone handset requires that the charger cradle is plugged in with power and phone signal. Make sure you have done that.
Nov 07, 2014 | Vtech Lands Phones
Out of range
Ok. My problem was that the main phone and answering machine worked fine, but the second handset kept saying, "Out of range" no matter what I did. If I tried to make a call, it would say, "Connecting...", but after a while, "Out of range".
I followed the manual which offers two mechanisms to deregister the phone. The first method (press Menu soft key...) went through the motions and then said, "Out of range"!
The second method in the manual worked - after I worked out what the instructions mean!
So here's the answer:
After that, for me, everything worked.
Jul 08, 2011 | Uniden Cordless Phone
I would like to purchase a Jenny Lind Cradle where can I purchase one
If you go to http://www.angelline.com/products/cradles.html They have the Cradle you are looking for in a various range of colours, the Jenny Lind one is the one on the bottom on the cradles page,
Hope this helps
Mar 02, 2011 | Angel Line Jenny Lind Cradle
Handset out of range
I'll give it a shot. Have you tried re-regestering the handset? Press and hold down the "end" key (on most models it looks like a red handset) while holding that key down, press and hold the # key, after a few seconds the unit should beep and show:
(SYSTEM RESET)
Deregister HS
BaseUnavailible
Useing the four-way key select "Base unavailable" and press the menu key The LCD display should then show :
"Which Base?"
Base #1
Select base one and then the display will show
"Base Unavailible
Yes
No
Select "Yes."
Your handset is now unregistered. To re-Register the phone to the base do the following. If the base unit has a charging cradle, just set the handset in it and it should register on its own, if you have a cordeed base, or the unit will not register when you set it in the cradle on the base go to menu and select register handset, then press and hold the # key on the handset for 2 - 3 seconds, it should beep and then start the registration process. If you have 6 handsets registered to your base, you will need to de-register teh non-working unit from the bases memrey before you will be able to re-register the handset.
Jun 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
My uniden phone says - out of range
I just finished fighting my phone for this same problem.Try unplugging the base for a minute and plug back in. I had a dead battery, changed it, it still said out of range. Next I deregistered it by holding the "off" and # buttons until the menu popped up saying "deregister". I had to select "deregister without the base" to get it to work. After all this, I unplugged the base, and that is what solved my problem.
May 25, 2010 | Uniden TRU9585 Cordless Phone
Eebrom err
My wife dropped mine in the tub. When the phone is in the cradle the cradle and phone don't communicate. I'm looking to buy just the phone. Any ideas
Jan 19, 2009 | Olympia InfoGlobe Cordless Phone ol3020
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Nov 05, 2007 | Uniden DCT758-4 Phone
Vtech Cordless 6041 Phone Logo
367 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
