Question about HP DeskJet 5550 InkJet Printer
Deleting completed print jobs on deskjet 5550
How do I delete?
  • Ron Watson Jun 22, 2008
    Can't delete completed print jobs with HP deskjet 5550, running OS 10.5.3 on MacBook Pro.
  • HP Master
  • 13,433 Answers
Right click and delete. If they don't disapear try deleteing the printer and then adding it back.
Posted on Jun 22, 2008
    Master:
  • 848 Answers
You can delete it
    Guru:
  • 1,894 Answers
Just disconnect the printer for 5 or 10 min from computer and reconnect it
u r done i think
Will not delete a print job says deleting but it has been 2 hours now and still in que
  • Turn off the printer and the computer.
  • Disconnect them completely from power.
  • Reconnect them after a while.
  • Check the print job now.
Hope it helps.Thank you!
Sep 29, 2011 | HP Deskjet 5440 InkJet Photo Printer
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
I'm trying to cancel a printing job. I tried the cancel button. After a minute it resumes printing. I tried unplugging and the same thing happens when I replug.
go to the right hand corner of you monitor and righ click the ptinter incon and go to printing go to open all active printing highlight the one you want to cancel and go to documents and click on delete hope this helps
Dec 12, 2009 | HP DeskJet 5550 InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
My printer has a job waiting that I can't cancel. I've tried everything including turning off the printer to erase the memory, and completely restarting my computer. Nothing will delete this print job
your job is stuck in the printer que, to cancel this go to control panel, open printer and other, right click on the printer icon, delete the job in que (are you sure you want to delete, yes)..........and you are done
May 10, 2009 | Office Equipment & Supplies
Deleting completed jobs
Try going to System Preferences (either in the Dock or from the Apple Menu)
Then Print&Fax
Then on the left side of the window is a list of all printers.
If you double-click on the printer, another window opens
Your old print jobs should appear here.
Choose Select All from the Edit menu (or Command-A)
There is a Delete button at the top left. Click it and the old print jobs should be erased.
Jun 07, 2008 | HP DeskJet 5550 InkJet Printer
Blinking Light
uaually the LED blinnks when there is no ink or when it runs low on ink. But since the LED is kept there to indicate any error happens to the printer.... 1. So I suggest that you should take out the printer cartridges and check all of them....shake well before you put it back. Now open Control panel - printers and fexes - right click HP 5550 - Properties There should an option to see the ink levels. If you can see the ink levels....it means that printer can detect the cartridges. Now the printer LED should be turned off. If the above doesn't work, try this; Check the printer que .. if there are print jobs pending, the LED will blink. Delete the print jobs, and restart the machine. This should solve your problem.
Oct 02, 2007 | HP DeskJet 5550 InkJet Printer
Well, first things first! Are you using the parallel port (the "wide connector" one) to connect or the USB(The small connector)? Get back to me with this info to continue troubleshooting! regards, babb
May 04, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
Seeker5211
Seeker5211
