Question about Microsoft Xbox 360 Console
Xbox live is not working and it is saying that no connection detected when i setup a wireless router frm the computer. how do i get a connection going
Como crear mi direccion ip
Posted on Jun 07, 2008
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
I have a wireless internet connector for my xbox and i cant seem to get it to connect to xbox live. i can get it to read that there is a connection to my computer and the signal is stong but i it wont...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Dec 23, 2010 | Belkin N150 Enhanced Wireless Router...
I just bought this router and am trying to get it connect with a Verison wirelss USB mobile broadband. How can I connect it to my computer and an Xbox 360?
For Verizon i found that Currently, the DIR-412 Mobile Broadband Wireless Router is the only D-Link router that is 3G compatible. The DIR-412 supports 3G USB adapters complying with HSUPA/HSDPA/EV-DO/TD-SCDMA networks and works with most major cellular carriers (AT&T, Sprint, Verizon, Rogers, Telus, Bell, etc).
D-Link routers empower gamers to easily connect their Microsoft Xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and Xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft Xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to Xbox Live.
  • Click here to upgrade your firmware.
  • Click here for Xbox Live setup instructions with a router.
  • For Xbox Live support, please visit www.xbox.com.
  • If you need more help come back.
    Post / thumbs / testimonial are welcome!
    Dec 22, 2010 | D-Link DIR-628 Wireless Router
    XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
    Please follow the steps below to setup your Xbox with your Linksys Router:
    1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
    2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
    3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
    4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
    5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
    6. Select the Connect option and press the “a” button on the controller.
    After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
    Aug 17, 2009 | Linksys Wireless-G WRT54G Router
    Xbox live cannot connect to network
    I would suggest power cycling it, both the xbox and the router, sometimes routers can be funny with there connections.
    Jun 30, 2009 | Linksys Wireless-G WRT54G Router
    Wireless not working
    Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
    As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
    If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
    Apr 10, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
    Ps3 goes online to web, but can't connect to other players online
    open these ports in your router and see if that helps.
    TCP: 80 443 5223 10070 10080 UDP: 3478 3479 3658 10070 Please follow the steps below to setup your Xbox with your Linksys Router:
    Armymason
    Mar 02, 2009 | Linksys Wireless-G WRT54G Router
    The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
    How Can I connect a network adapter from my room to downstairs about 20 yards away?
    I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
    The router downstairs is a TalkTalk modem help me!
    Jun 28, 2008 | Computers & Internet
    Computer, xbox live setup
    the easiest way is to use another computer connected to router in any way.
    windows xp os.
    click start/run type in : cmd
    then type in : ipconfig
    there is the default gateway number.
    Jan 26, 2008 | NetGear WGR614 Wireless Router
    Microsoft Xbox 360 Console Logo
    24 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
