Question about Akai PDP4206EA Television
My tv picture is bouncing up and down
Akai pdp4206ea I have an Akai PDP4206ea plasma tv. I use the tv as my computer's monitor too. My problem is the tv on comes in black in white as it does with the dvd player. However when using my computer the colors are fine. I am hoping that this is an adjustment issue that I am missing. In the menu mode, the menu's colors are as they have been as with the blue screen upon turning on. If anyone has any suggetions if this is fixable either through adjustment (im hoping) or repair, thank you very much in advance for any help. Scott Williams Fresno CA
    Sergeant:
  • 154 Answers
May be there is a problem in setting of ur colours
Posted on Jun 07, 2008
  • santha ram
    santha ram Jun 07, 2008
    As I understand it now, the color is gone only when in AV mode.
    You may have to have your PS checked or backtrack any settings that have changed.
    Hope this works for you and pls post back results that we can figure something else. Cheers.
  • santha ram
    may be the problem is with connection of cables
    These should be something like yellow, red & white (sometimes its
    black). Normally it is the yellow that is used for video. You can try
    wiggling it a bit both on the PS side and that of the TV while watching
    to see if the wiggling affects the display (color or no change). You
    can also temporarily replace the yellow with either the red or white on
    both the PS and TV side and see if it works, if it does then the
    problem is your RCA cable as it is called
Blue will not adj on akai 42 plasma odel pdp4206EA
it is convergence STK chips IC problem,replaced this two STK, so it will normal again...
Hope this may help;
Regards,
VOTIT
Jul 26, 2008 | Televison & Video
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE unstable vhold ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
I had the same problem... It's the main board. Unfortunately they're pretty scarce these days. You can try to get a Viore mainboard, but you're either have to make a 3.3v ttl serial cable, or desolder the flash from the akai board and put it on the viore board (the two tv's use different pdp's). The 1st option is a little less intense.
May 04, 2009 | Akai PDP4206EA Television
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
this is a shot in the dark but as the set been dropped? have you tried tapping around the case to see if this ulters the brightness. you might have a hairlined crack in the main pcb or dry joints.good luck .farr64
Apr 29, 2009 | Akai PDP4206EA Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
Akai Plasma
Had a friend with same problem. Found out to be a lightning strike. Strangely enough, the colour came back 4 months later on it's own.
Not much help, I know.
Nov 04, 2007 | Akai PDP4206EA Television
A WONDERFUL MAN NAMED LARRY AT 251-479-3567 HELPED ME WHEN AKAI WOULD NOT CALL HIM.
Apr 14, 2007 | Akai PDP4206EA Television
Televison & Video Logo
149 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
