Question about Singer Sewing Machines
Just purchased a Singer Inspiration model 4205. Seems as if the feed dogs do not align properly with the holes in the needle plate causing the plate to move up and down as the feed dogs move.
    Genius:
  • 1,788 Answers
Take it back where you bought and have them show you how to do it. Or, see is you can tighten the needle plate yourself, If, you can't call Singer (1-800-4singer) and find out where the authorized service center is. You should not have to pay anything with it being new. Good luck
Posted on Oct 24, 2010
SOURCE:
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
Nov 30, 2017 | Singer Sewing Machines
Singer sewing machine model 7005, dog feed is not working. Where is the lever to adjust the dog feed.
The Singer Imperial 7005 does not have a feed dog lever. Instead there is a feed dog cover that gets placed over the needle plate. To remove the cover, raise the needle and presser foot. Open the slide plate, then lift up the front edge (closest to the bobbin) of the cover. Then pull the feed dog cover away from the sewing machine.
See page 10 of the manual; it's page 12 of the PDF. The manual is available at the Singer manual search page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/676_7005.pdf .
I hope this helps.
Sep 13, 2017 | Singer Sewing Machines
How to fix a hook & timing issue on singer inspiration 4205?
I would over ride the auto setting and trial and error the process by manually turning the tension my self, also it has to do with the fabric too, sometimes whatever fabric is being used tends to regulate the tensioner too, good luck
Sep 01, 2014 | Singer Inspiration 4205 Mechanical Sewing...
Hi... I put new 2 gears which operate feed dogs.but my singer stylist 513 sewingmachine's feed dogs still jamed.not moves
The feed dogs must be centered. If the dogs rise too high the material may get stuck and cause problems. Another problem could be the foot is too high of pressure and must be lowered to allow the fabric to move. The last thing to look for is to check if the feed dogs are above the plate at the same time the needle is above the plate. All of these can cause trouble. It is also possible to have the plate have an area that causes a snag. Check the plate where the needle goes in the plate and check the edges of the hole. If they are rough then you can likely use a finger nail file to smoothen the edges. These are all very important to check.
May 29, 2014 | Sewing Machines
Singer Inspiration - needle breaks - needle lowers into hole but edge of hole hits needle before it is raised out of hole - is this a timing problem ? I would appreciate any help asap as I am making a lot...
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
also make sure to use the right tension for what your sewing
also clean under the needle plate & bobbin area for lint or loose threads
if these suggestions don't work & stop the needle breaking then it may be neccessary to have the machine serviced
Sep 14, 2011 | Sewing Machines
The material wont go through you have to pull it rather than the machine feeding it the sewing machine is a singer inspiration 4205
Maybe you should check your feed dog it may be down instead of up to walk the material thru...
Jan 17, 2011 | Sewing Machines
I just received a singer 4205 (inspiration) and the presser foot does not move back and forth to pull the material through the machine. It seems to be stuck. I am not a seamstress, but 3 other people...
It is not your presser foot, you must mean the feed dogs, they are what moves the fabric along. Clean and Lubricate your machine. Remove the bobbin case and clean it out. Replace your needle now Totally rethread the machine, according to your manual. Test the threading by putting the presser foot up, pull on top thread, it should pull smoothly, now put your presser foot down, the thread should barely move. This will seat the thread in the tension discs. By the way, try your tension on 3. Also, make sure that your presser foot is down before sewing. Always move the handwheel towards you, never away from you because you will mess up the timing. You will see your feed dogs move if you watch. Download a free copy of you manual at www.singerco.com and save it, plus enlarge the diagrams. If, that does not do the trick call Singer at 1-800-4singer.
Dec 25, 2010 | Singer Inspiration 4205 Mechanical Sewing...
How do I thread a singer inspiration 4205
sewusa.com has threading diagrams
singer.com has a free manual to download just put in the model number in the search box
Dec 02, 2010 | Singer Inspiration 4205 Mechanical Sewing...
The machine needle is no longer in the correct position
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Sep 01, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
