Question about Marzocchi Cycling
Hi, i have a pair of marzocchi dj3 currently on my bike and a pair of marzocchi dj2's on my old bike. i would like to change my dj3's back to my dj2 as more travel and suited to my riding uses. although the problems i face are that both steerer tube are different lengths. The dj2's steerer tube is about an inch or two too short to fit my new bike but the dj3's fitt fine is there any way to swap only steerer tubes from fork to fork to result in having a longer steerer tube on old forks please help. many thanks Sam Brown
  • Marzocchi Master
  • 1,379 Answers
The steerer tube is not listed as a separate part, therefore it can't be switched. Considering how critical it is to have strength at that junction it's not surprising that it is integrated.
2012 DJ 2 2012 Forks Marzocchi MTB Suspension
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on May 11, 2017
SOURCE:
  • 1140 Answers
SOURCE: Where can I get a
Try this link:http://www.marzocchi.com/Template/listManuals.asp?LN=UK
Posted on Oct 19, 2010
Coachphil
  • 347 Answers
SOURCE: how do you fit the Marzocchi
The easy answer is take the rigid fork of your current bike and replace with the Suspension fork.
The complicated answer is you may not want to run that fork, The reptiod which uses the same basic frame is set for an 80mm travel and your fork is a 100mm travel. So to get the bike to handle correctly you would probably want to replace the headset with a Cane Creek Angleset along with your fork, and even then it may pitch you to far back on the bike, but it would be interesting to try.
I would not suggest doing this yourself unless you have the necessary tools to install the headset, install and remove the crown race and install the brakes. That is alot of speciality tools and will be much less expensive to have the shop swap forks.
Posted on Nov 23, 2010
Coachphil
  • 347 Answers
SOURCE: I have marzocchi 2001 z1
Marzochhi has a great website with the tech manuals for all their forks and other general instructions.
Here is the link to your specific Fork manual. if it takes you to the owners manual page just type in your model (Z1) and year (2001) in the boxes and your manual will be there. There are two versions of the Z1 from that year the DO and MCR. Also in the tech section are tips and other technical help.
Good luck with your rebuild project, go slow and follow the manual.
Posted on Jan 27, 2011
joeguest2
  • 2080 Answers
SOURCE: I have a marzocchi mtb
Since you are unsure of exactly what model of Marzocchi fork you have, here are some links to a set of YouTube videos which show the detailed Marzocchi fork rebuild procedure for a couple of different shocks:
66 RC2X Part1
http://www.youtube.com/watch?v=XeNZr5dA4Q4
66 RC2X Part2
http://www.youtube.com/watch?v=ZvMK3iFzkr0
XC600 ATA2 Part1
http://www.youtube.com/watch?v=viCvBG4RH8c
XC600 ATA2 Part2
http://www.youtube.com/watch?v=J3UchZKRJzY&feature=related
And here is the link to the Marzocchi website with all the available fork manuals for 1996 including the XCR:
http://www.marzocchi.com/Template/listManuals.asp?t=&tp=113&idMY=2140&Azione=Search&IDFolder=126&LN=UK&idC=1561
Just use your mouse to click on the linkS, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Posted on Jul 05, 2011
I baught an old Specialized Hardrock Stumpjumper and the front forks are Marzocci XC the out side seals look fine, no cracking but they have leaked fuid all over everything, How hard is it to rebuild these...
There are severall answers to this question (with videos) if you use a search engine for "rebuild marzocchi xc fork". You can get creative with the search terms.
As far as parts availability is concerned, scour the web (search engines again) or eBay.
Maybe hit the marzocchi site, register and ask them or search for documentation.
https://www.marzocchi.com/Utenti/login.asp?LN=UK&idC=1580&URL=%2FUtenti%2FSupport%2FDefault%2Easp%3FLN%3DUK%26idC%3D1580
Jun 16, 2011 | Marzocchi Cycling
Hi my forks are 2nd hand off ebay, they are marzocchi dirt jumper 3s and every time you compress them, even slightly, there is a sort of click/knock sound. is this normal or is there something wrong? what...
The best thing to do is take your forks into a bike shop that works on suspension and have them take a look. It could be low on oil and/ or air and bottoming out or it could be something more serious.
If you know the year of the fork you can pull an owners manual from the Marzocchi website. They keep a running inventory of all their manuals in PDF, this will also help to diagnose the problem and let you know what you will need to overhaul.
Apr 07, 2011 | Marzocchi Cycling
I have no shock pressure, how do I add pressure?
I would suggest you visit www.marzocchi.com and go through the tech section. There are manuals, videos and more on your fork. It is good to know not only the basics but regular maintenance schedules and when to take into a shop for an overhaul.
Specifically to add pressure you need a shock pump to add air. Going back to the website reference they will tell you how much for the type of riding yoiru doing and your weight.
Jan 07, 2011 | Marzocchi 08 66 Rc3 Mountain Bike...
Hi i bought a kona stinky 2008 and the front 66rcv are stiff.how do i release air.do i unscrew the nut on bottom of the fork.also the rebound screw dosent move.any help good thanks.Also how do i get the...
This is most likely not the answer you are looking for, but I would highly recommend taking these into a bike shop that has experience with the Marzocchi's. These are fairly complicated and require some speciality tools, and extremely easy to do damage that will be an expensive fix later.
First red flag is that the rebound screw does not move. A fork overhaul is probably in order, replace the seals and oil, check all the screws too make sure they are not stripped, adjust the air pressure, and so on. The bonus is a shop that can perform this overhaul, will also be happy to show you how to maintain the fork and how to adjust everything properly, and if you don't have a fork pump, sell you that as well. Trust me, these can be challenging without knowing exactly what you are doing, I am highly trained and I still have issues now and then with Suspension Forks.
I have included a video with a Marzocchi tech guy explaining a slightly newer version of your fork, Yours is basically the same.
Here is the link to the Owners Manual for your fork. If this is not correct you can get any manual for any fork they have made off the Marzocchi website under tech.
Dec 21, 2010 | Marzocchi 08 66 Rc3 Mountain Bike...
How do you fit the Marzocchi 4X World Cup Forks 2009 to a dmr drone?
Nov 23, 2010 | Cycling
88 Ducati Paso 750 the rear marocchi shock is leaking need to find rebuilder here in the states
Hi, Brnboxer1 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
ducatipaso org View topic servicing marzocchi rear shock
ducatipaso org View topic Stripping Marzocchi rear shock
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 13, 2010 | 1989 Ducati 906 Paso
Can u convert 08 marzocchi 80 mm forks to 100mm if so ?
You can convert to the longer travel fork (assuming that the 100mm fork is new and the steerer tube is as long as the 80mm you have on the bike now). You should be fine with the additional 20mm of travel, but be aware that it will change the geometry of you bike (the front end will sit higher) and it will likely take some getting used. Just take it slow and easy for the 1st few rides until you can be sure you are comfortable with the way the bike handles.
May 08, 2010 | Cycling
Need to no how much oil they should hold. they are 07 drop offs triple clamp
offical Marzocchi site has all the details.
(near the bottom for your drop offs)
http://www.marzocchi.com/Template/contenuto.asp?LN=UK&idC=1592&IdFolder=777
Jan 31, 2010 | Marzocchi 2008 XC 700 ATA Mountain Bike...
What is the best fork for my MTB ? i
You havn't actually mentioned the bike, but anyway, get some advice on which size travel to purchase, and a good brands to go for would be , FOX, or Marzocchi, Rock Shox are way over rated
Oct 10, 2009 | RTO Rock Shox Mountain Bike Bikes Fork...
Cycling Logo
91 people viewed this question
Top Marzocchi Cycling Experts
Marvin
Marvin
Michial Gueffroy
John Egan
John Egan
Are you a Marzocchi Cycling Expert? Answer questions, earn points and help others
