Question about Singer 3116 Simple
Sews great on top of the material but the bobbin thread is all knotted up
    Genius:
  • 1,788 Answers
I know that you do not want to hear it but your top threading is not right. Try this test, put your presser foot up and pull on the top thread, it should feed smoothly. If not, you are not making sure that the thread is going through the tension discs on your way down. Rethread and make sure you are not using old thead, Try using a new needle. Read your manual, all machines are different even if you have been sewing for years. If, you do not have your manual, download one for free at www.singerco.com and enlarge the diagrams to see what you are doing clearly.
Posted on Oct 24, 2010
SOURCE:
I have a Kenmore Model #385.12814490. Serial #307664. When I start sewing, the thread gets knotted up by the bobbin. My material comes out with lots of long looped knotted thread.
It's called bird nesting or thread nesting.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the upper tension to the midway point and then tweak it.
Oct 12, 2017 | Kenmore Sewing Machines
How to set the tension
The carrier and bobbin are removed. Place the thread in the carrier with the thread dispensing counterclockwise. Place the thread between the metal pieces (tension). let the carrier hang from your finger and bob it slightly. It should extend one inch. If it doesn't then you can adjust it by turning the small screw slightly until it does what I said. Now, replace this assembly. The top tension you can start at three. The sewing should be an even pull between the upper and lower thread. If the thread knot is in the center of the material it is right. If the knot is under the material then raise the upper tension. If the knot is on the upper material then you should lower the upper tension. The key is to start with the bobbin tension correct and adjust the upper tension until the knot is in the center of the fabric
Oct 26, 2014 | Sewing Machines
Ruffler foot bobbin tangles
I suspect that the bobbin thread you are talking about is in fact the top thread that has been pulled under the material, make sure that the top thread is pulled into the tention discs firmly and that there is no fuzz in with the thread, also make sure the top thread is properly threaded and is actually in the take up bar .
Apr 08, 2014 | Singer Inspiration 4206
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
Have been trying to adjust the bobbin pick up and seem to get that part the the thread gets caught in the bobbin mech or knots up on material
try to rethread top and bottom, and make sure the thread is seated in the top tension disc. I have owned a few Whites and had a lot of timing issues with them
Aug 14, 2010 | White Sewing 1418 Mechanical Sewing...
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
Kenmore model 385. 12912890
Make sure your machine is set to feed material. There may be a switch or knob somewhere on your machine to lower the "feed dogs" (the little metal teeth that pull the material through the machine). If they are down, the material won't feed so the machine will sew in place. More likely, since its knotting on the bottom, your machine is probably not threaded correctly. Rethread the machine, and try again.
Yes, the thread on the bottom IS the needle thread.
Nov 25, 2007 | Sewing Machines
Thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Jun 29, 2007 | Brother LS-1217 Mechanical Sewing Machine
Singer 3116 Simple Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
