Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side w/ water & ice maker refrigerator is not staying cold inside refrigerator and freezer won't freeze any foods GE serial#HF239414 model#GSL25JFPA BS .The sides are some what cold.How costly to repair. What do you think might be the problem.I bought new in 2003.Should I just buy a new one.
  • 10,515 Answers
There are few Steps that you could Verify and narrow down the problem :-
1. Compressor - Make sure that the Compressor should be working. When you ON the refrigerator, you could hear a clicking sound from the Compressor.Compressor could be Hot but not enough to lay eggs on it.
Note - In case, you find that the Compressor is Clicking and Shut Down the machine every now and then, more often that's an indication of Faulty Compressors. With most Brands, they do come up with 5 Years Warranty.
2. Make sure all the Fans are Working. I have seen many times, that the Fans are not working and the people are Inspecting other Components in the Refrigerator.They should also be running at Optimum Speed.
3. Do you see any Ice in the rear of the Freezer? More often - Frost. ( Not Crystal Clear ). If yes, take a Blower / Dryer and melt it. You would see a complete Difference.
4. Make sure that the Condensor Motor is working. If you could hear Condensor Fan is running, it always indicate that the Motor is Fine too.
5. How many times we never clean up the Evaporator Coils? We are using it for Years and we never clean it. So, if this is the Case, time to Take a Vacuum and clean the Evaporator Coils.
6. It could be a Defrost Problem. There are many Components but How could you make sure?
The Best Way - Disconnect the Power Supply and Unplug the Cord. Take everything out of the Refrigerator. Keep the Doors Open for 24 hours. After 24 hours, plug in the Cord and then Turn ON the refrigerator.If you see that there is Some improvement, more likely you have faulty Defrost System.
7. On other Occasions, i have Found Overload Relay to be one of the reasons. I solved many Problems where the Customer Actually Test and Find that the Overload Relay is at Fault.
Note - There could be Freon Leak or Gas Leak which i am not considering right now. You need to contact a Licensed Professional t check these.
Above mentioned are few steps that you follow to narrow down the problem. Unless call a repairman to fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 24, 2010
SOURCE:
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
