Question about Eliminator MotoMaster Mobile Power Inverter 700w
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
    New Friend:
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Posted on Oct 27, 2010
SOURCE:
Reemoveing six six volt batteries and replaceing them with three 12 volts in the nss burnisher and how to hook up the cables
If the 6 volt batteries are wired neg to pos to neg to pos to neg etc, then do the same with tha 12 volt batteries. So neg on one to pos on the next, then neg on that one to pos on the third. (- +) (- +) (- +)
Dec 07, 2017 | Cars & Trucks
Starter spins correctly when I hook pos to neg and neg to pos
Sounds like someone has changed the starter recently and they have the negative cable from the battery hooked up to the starter solenoid. You need to have the positive cable hooked to the starter solenoid not the negative cable.
Jan 02, 2016 | Cars & Trucks
My 77 Chevy c30 has no power. Jumped started it and drove it home. I turned it off then tried to restart it. No power no lights. nothing. Battery is good. An u help will be appreciated.
If the battery is good you will need to follow flow. Test light is the easiest to use. First hook light to ground and touch pos terminal,lights good next touch pos battery cable end, lights good. Next follow pos cable to starter pos terminal,lights good. Next hook test light to bat pos teminal,touch neg terminal,lights good. Then touch engine block, lights good ground. Next move test light clamp back to ground/neg side and touch alt pos terminal,lights good.if all that tests good, if all good move inside and check for power at ign switch pos term if at any time you dont find power you have wiring issue that needs to be addressed. Let me know what you find. Russ
Mar 29, 2015 | Chevrolet Cars & Trucks
How do I hook up this unit Two wires or four
Almost all car batteries have 2 pos and 2 neg. More precisely, 1 pos post and 1 side connector, 1 neg post and 1 neg side connector. You only usually use use one set or the other depending on what connectors are on the end of your cables. You can connect something else to the side posts if you need to, but generally only pair is used.
Feb 28, 2015 | Cars & Trucks
Someone hooked jumper box up backwards on van and tried ti start it it ran great before that after it wouldn't start at all changed the computer now it starts runs a few mins then shuts off what could it...
You will have to take it to the Dealer. You may have burnt out or the "Control Module" needs to be replaced or reprogrammed. Make sure the battery has not reversed polarity also.
Feb 13, 2015 | Cars & Trucks
I replaced the battery terminal cable ends. Now the car will not start, There is a clicking noise from the starter.
Bad connection on cable ends or where they connect to battery. Quick check is if you have a good set of jumper cables, use the jumper cable as a replacement for what maybe the defective one. Hook negative cable good to battery neg. post and then put other side on neg cable to engine ground on block. See if it cranks, if it does than the trouble is on the neg. cable. If not then put positive cable on pos. post of battery. Then put other side of pos. cable on the starter post, try to start. If it cranks then the trouble is on the pos side of cable. Hope this helps.
Nov 16, 2013 | 1996 Geo Prizm
John deer mower
Possibly just the fuse. But if you say the jumpers WERE positive to positive and neg to neg it shouldnt have been a problem but maybe the pos clamp touched the body. That would have cooked the battery. First check the fuse, if thats ok then connect your neg jumper lead to the chassis of mower to neg of truck and the pos to pos of truck and hold the other end to the large terminal on starter motor.This will bypass everything and only test starter. Engine will spin over if starter motor ok. There will be a strong spark when touching terminal so watch for fire hazard.
Jan 30, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Gauge showing low output alt only 1yr old wondering if it could be regulator or batt or wiring
if you have access to a digital multimeter, connect the meter (set to volts) across positive and neg. terminal of the battery, should read roughly 12.6 volts, close to 10 volts, battery may be going out, also test the alt output, disconnect neg term and place negative lead to battery neg post and positive lead to neg battery cable (make sure meter is set to amps) should read near the rating, if both those, then you'd want to do a resistance test, (set meter to Ohms) disconnect battery and connect meter neg to either pos cable terminal or where the pos cable connects to the alt and connect positive lead to opposite of neg, should read next to 0, the check resistance of the ground by connecting meter between batt neg cable and body of alt.
- Spenser
Apr 04, 2011 | 1988 Ford F 250
Dead battery. How do I hook up a charger? The owners manual is NO HELP
with the charger unplugged. connect the pos(+) cable on the charger to the pos(+) battery terminal. then connect the neg(-) cable on the charger to the vehicle's chassis. pick a spot that is unpainted like the head of a bolt. then plug in your charger.
Sep 25, 2010 | 2005 Ford F 350 Super Duty
How to hook up 2 new batteries
hook them up in parallel, pos to pos, neg to neg from one battery to another, then pos cable to battery prs and ground cable to neg battery
Jul 29, 2010 | Renault Fuego Cars & Trucks
Eliminator MotoMaster Mobile Power Inverter 700w Logo
1,121 people viewed this question
Top Eliminator Electronics - Others Experts
fisherman816
fisherman816
Ngoro
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
