Question about Fujitsu 24C1 Air Conditioner
Fujitsu remote control unit /MODEL AR-RY16
Tried turning it on today for first time since winter...won't go on...replaced batteries...still no good...when I press ON, the screen goes blank...when I press STOP...temp. number comes back on...did the remote go bad just sittting there? there a way to reprogram it...???....HELP
  • 1 more comment
  • TheSeanTeam Sep 22, 2008
    I have the same issue with my remote.
  • imajenfly Oct 06, 2008
    Same issue here. Now I am shopping for a new remote.
  • Anonymous Oct 23, 2008
    i have the same problem because i replaced the batteries in winter when the heater was on and now the rempote doesnt turn the air con on or change the degrees.
My remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Posted on Jul 22, 2013
SOURCE: Wall Hung A/C unit remote
I just got onto a technician who solved the problem for me. What he had me do was:-
  1. Pull dowwn the slider and use a pen to press the ACL button.
    That didn't fix it so...
  2. Take off the slider (the way you would to change the batteries). There is an ABCD slider switch and mine was set to "C". I moved it back to "A" and now it works! I am not sure how it got to "C" though ???
The other thing is I had been messing around with the "Manual/Auto" button under the grill on the wall unit. It was set so that the A/C was off. I'm not sure if that is significant.
Hope that helps.
Garry Rogers (ausgaz)
Posted on Jan 04, 2009
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
  • 400 Answers
SOURCE: Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Posted on Nov 04, 2009
  • 10 Answers
SOURCE: can't open the remote controller on Fujitsu Model
Try tighly gripping both sides fo the slide down section to loosen it then slide it down wards.
Posted on Jul 15, 2010
  • 17130 Answers
SOURCE: Dear expert, Our dog chewed up
Get your Dog to the nearest VET immediately. The next thing is to ask your Fijitsu dealer for a spare remote control.
If not then you must check out if the multipurpose remtoe will work out with this model.
Get help from an accessories shop to give a remote to test/replace before buying.
Posted on Sep 11, 2010
My remote control is not working i have fujitsu air condition model #AR-RY6 can i use different model ?
There are some other Fujitsu models that will work but not all. The remote controls from Fujitsu themselves are not too expensive if you want a genuine one. Call them for a replacement or try a cheap universal remote from somewhere like ebay or Aliexpress.
Oct 15, 2016 | Fujitsu Heating & Cooling
I have a fujitsu a/c unit. Remote Model AR-RAH2U. If I push the on button, the a/c goes on-screen remains blank. I can not adjust the temperature or anything else. I have replaced the batteries.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display.
Hope answer the question
Aug 07, 2016 | Fujitsu Heating & Cooling
Remote control unit model ar je5
That specific part may not be readily available.
May 24, 2014 | Fujitsu Televison & Video
New Fujitsu remote AR-DJ8 will turn unit on but will not turn unit off
Try new batteries before you buy or repair anything.
Feb 10, 2014 | Heating & Cooling
Ar ab9 fujitsu
There is no such reset to this remote control. Just take out the batteries from its battery compartment, and re-insert it after a minute. The remote control will reset itself.
Jan 16, 2014 | Fujitsu Televison & Video
Fujitsu remote control Model AR-DL10. I need to change the batteries. I can pull the slide down to expose the set/ swing/ energy save, but I think I have to pull it further down to get to the batteries. ...
How to get to the batteries in a AR-DL 10 Model Fujitsu Remote Control/ A/C
Pull it down to expose the controls inside.
To pull it down further to expose the batteries: PINCH BOTH SIDES OF THE slider at the top where it is knurled so it will bow out a little bit in the center AT the same time you may need to
slide an object under the slider to help it bow up a litter further.
WHILE DOING THIS: pull the slider further to expose the batteries. There are two plastic stops that the slider must clear to pull it down enough to get the new batteries placed. Before putting it back together: File down the two stops with a nail file so it is easier to do next time. - Who engineered this?
Sep 11, 2010 | Fujitsu (FPCRC04AR) Remote Control
Replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Jan 15, 2009 | Heating & Cooling
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace idea abt w.canada
Dec 01, 2007 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
1,901 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
