Question about Sony Audio Players & Recorders
My Sony MHC-EC98P Cuts off 60 seconds after being turned on. Every time I plug it up, it shuts down. I need some help with this issue.
SOURCE:
SOURCE: sony 60 cd changer mhc-gs300av
The audio amplifier IC is damaged and need to be replaced
Posted on Feb 11, 2009
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID [email protected]
any sony music system problem
Posted on Nov 07, 2009
Sonys built-in protection against shorts in the speaker system - of course, like it was by my CMT - CPX1 - there's no problem at the speakers at all - this have to be insured! If everything with the speakers and the speaker cabling is ok it might be the soldering at the S-Master IC's. The S-Master Unit is Sonys Digital Sound System, you'll find inside two identical S-Master IC's srewed togehter on a heat sink.
I recognized that if I opened the system, it was running, touching sometimes the S-Master PCB, it shut down.
Solution: there's a bad / poor soldering at the S-Masters pins (probably because of the heat sinks!). I resoldered all S-Masters IC Pins - that's it - my system is running now.
Posted on Apr 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: Im having problems with my
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 01, 2011
lestat_001
SOURCE: Power shuts off when CD/tuner/Tape Button is pressed
check your wires for your speakers/sub. when i added an extention to the wires for my stereo, if they become loose or rub together they short out the system and it will shut off like mine did
Posted on Jul 19, 2012
My sony mhc-rv777d is not working when i on my sony within 4or 5 sec it off automatically so i need a solution
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 03, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony MHC 881 -How do I get out of Demo Mode?
Press the Display/Demo button. The power cord needs to be plugged in, but the power must be OFF.
Sep 01, 2009 | Sony MHC-881 Shelf System
My stereo system blinks PROTECT on the screen
one of the out put tran is short ,
there normaly 4 to 8 of them
screw to a big heat sink ,
easy to get to.
check with a volt meter
then google the part
they cost 8.00-12.00
Mar 17, 2009 | Sony MHC-EC98Pi Shelf System
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Sony LCD Projection TV turning OFF!!!
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Apr 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony 60 cd changer mhc-gs300av
Nov 21, 2007 | Sony MHC-GS300AV CD Shelf System
Sony MHC-GX9900 Shelf System
i have the same problem with the blinking light this problem is due alot to over heating be careful your fan is not burned up or is not being blocked it is a protect mode activation to prevent overheating
Jul 04, 2007 | Sony MHC-GX9900 Shelf System
Help
No, I doubt if the surge device is causing your problem. most likely there is a power supply issue, or a fauly with one of the servo or motor driver circuits. This is not a repair or a quickie fix for the end user I'm afraid. This unit is going to need to be taken into a repair shop to be diagnoised. Good Luck
Jun 13, 2007 | Sony MHC-GX450 CD Shelf System
125 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
