Question about Technics SL-DZ1200 CD Player
I have a Technics CD player, model SL-P9066. When I turn it on the 5 cd turntable starts turning and will not stop. Any suggestions?
SOURCE:
  • 7 Answers
SOURCE: Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Posted on Jan 05, 2008
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
jomabug76
  • 1148 Answers
SOURCE: Technics SL-PG440 CD player no audio output
GET NEW RCA JACKS
Posted on May 15, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
SOURCE: Technics SL PJ27
First I think you should turn your player on and wait 5 - 40 minutes before before you start liste3ning music.
because electrolytic capasitors may be little broken and those can repair themselves but it takes a while.
Good rule of thumb is that If you don't use every day an old device
then you should give to it every time a soft start . like I mentioned earlier
turn power on and wait.
Second try to play music cd which don't have any scratches and without any copyprotections
Third Disconnect power cable
Then open device and try to clean all dust.
Look for hairs and other difficult to see objects uselly
you find at least one hair inside old cd player.
If hair is around disk spindle it maybe difficult to
remove.
Check that cd-disk makes good contact so remove even tiniest dust and hairs
between cd-player and copact-disk. It may be called spindle or what ever but
still try to clean it with Isopropyl alcohol and remove dust and filth.
Check laserlens and is there some dryed liquid stains if there is try to remove those
with Isopropyl alcohol and swabs. Don't use any force and you can tear a top of swab little longer
(about one inch) and you get swabs which are much easier to use these kind of delicate cleanings.
Lubricate every moving part with lithiumgreese don't make any mess.
This last fix is for most desperate ones.
Connect the power cable and push eject and be carefull because
you can get fatal electric shock.
Disconect power cable. You can use extension cord which have on/off powerswitch.
You can see six tiny trim pots.
First take photo of those pots so you can undo all changes.
Change only one pot and only about 1/8 of turn. Turn power on and test if you make it worst or better.
If you think you fixed the problem that is not the case ... yet.
Then you have to make finall test and play a lot of music cd:s and after that you have fixed the problem.
Make notes which cd:s and what track your player don't play properly and use those
cd:s to testing those trimpot changes.
Posted on Dec 30, 2009
My player drags in turntable mode
It must be reseted. Try unplug power for ten minutes and replug. If no result check if you can remove its internal small battery and refit.
Sep 20, 2008 | Technics SL-DZ1200 CD Player
I have a technics CD player with volume problems
Any cd player will only have one level output, i think you may have it plugged into the "phono" connection on your amp, which is different for turntables, please recheck.
Feb 28, 2015 | Technics Audio Players & Recorders
I have a technics Sl-dz1200 and it keeps ejecting the cd within 5 secs of putting it in. Any ideas? thanks
The most common cause is dirt on the lens of the player. This can be cleaned off in a verity of ways.
Oct 07, 2014 | Technics SL-1210 Turntable
What CD types does the PD887 play (CD-R, CD+R, MP3 format)?
You will have to experiment on this unit. I have looked at the owners manual and it does not refer to ANY type of recordable media. Your unit may not be able to play any recorded media. That is why I suggest that you try -R first, then you may want to try a Audio CD, specifically made for audio.
Here is a link to your owners manual if you need it.
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PD888
I hope that this helps you.
If you need any further assistance please respond to this post.
asnowman
Apr 12, 2010 | Technics SL-PD887 5-Disc CD Changer
CD tray on Technics SL-PS670A compact disc player will not close
Just a quick notion! Had you made sure the transit locking pieces were removed?
Jan 10, 2010 | Technics SL-MC6 CD Player
Turntable mode does not work
CHECK SENSOR & SENSOR SHEET UNIT DISPLAY UNIT
MAKE SURE NO LIQUID WAS DROPPED INTO UNIT
Mar 18, 2009 | Technics SL-DZ1200 CD Player
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
Technics SL-DZ1200 CD Player Logo
137 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
